Got three issues in an otherwise perfectly running CF
1. my skin is able to cause an exception dialog whereas usually error go in the error.log. The error pops up when I hit the mute button I've created. It only pops up when going from not muted to mute.
The error:
Code:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.Collections.ArrayList.get_Item(Int32 index)
at centrafuse.tvslider.mainTimer_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.Callback(IntPtr hWnd, Int32 msg, IntPtr idEvent, IntPtr dwTime)
full error dump available)
The button definition:
Code:
<MUTE>
<X>0</X>
<Y>704</Y>
<WIDTH>128</WIDTH>
<HEIGHT>64</HEIGHT>
<FONTNAME>Century Gothic</FONTNAME>
<FONTSIZE>14</FONTSIZE>
<FONTSTYLE>Bold</FONTSTYLE>
<FONTCOLOR>#F2EFD1</FONTCOLOR>
<SECONDCOLOR>#000000</SECONDCOLOR>
<XOFFSET>0</XOFFSET>
<YOFFSET>0</YOFFSET>
<ENABLETEXT>False</ENABLETEXT>
<ALIGN>Center</ALIGN>
<TABINDEX>4</TABINDEX>
</MUTE>
Which is the same as for example my Random button (except for it's location of course
NB: after reloading CF, I haven't been able to reproduce this error...
2. Another error I caused, but might be handy to look into to prevent strange behaviour though human error/substandard skinning
Code:
26-11-2006 19:55:12
Value cannot be null.
Parameter name: image
at System.Drawing.Graphics.DrawImage(Image image, Int32 x, Int32 y)
at System.Drawing.Graphics.DrawImageUnscaled(Image image, Rectangle rect)
at centrafuse.cfbase.OnPaint(PaintEventArgs e)
Occur quite a lot, mainly because I've "disabled" some buttons and such in the skin I'm building... just to get them out of the way I've given them a width and height of 0.
Of course, that's something I've caused, but might be handy to build in a small check before just drawing these things?
3. Just a small one: when loading a list of mp3s with random mode on, it always starts at the first song in the list.
