The problem with the loss of focus when adding something to the playlist is still present. It was already on the list but it isn't anymore and hasn't been fixed.
I tried it again and now i know why it works for you, when using the mouse to click the "+" button the focus is given back to the list view but when you use the keyboard controls to press "+" the focus is still lost and you can't use the keyboard controls before you click anywhere on cf with the mouse.
I tried both... the inserts into access turned the 30 seconds to about 25... The hashed index didn't make much of a speed improvement at all...
The problem is not in the display, but inserting or adding it to a hash...
The sorting doesn't even take that long, it's getting it into a sortable object, array, hash, or DB takes a long time when dealing with 2.1 million records...
david
Okay, umm, your hashing may be confused.
On a much lesser processor, (an ARM7) I was able to get sub-second access to 100k ID3 records, and the response time stayed linear up to my bounds test of 1 million records. ...and I was doing this in 24k ("k", not "m") of RAM.
The record count doesn't mean anything, that's the purpose of a hash. Short of the file system having issues with fseek() you should be able to hit any place in that index file almost instantly. Once you're there, it's a short hop to your data.
Build the hash, save it to an indexed file, and you should be good. There's no reason to re-load the hash every time. In fact, since the data is static, you should be able to ship it pre-built with the release.
I'm happy to give you more specific help.... just PM me an example of the data (even just 20 random records) and I can generate a couple of million more from that. I'll carve out some code and get it back to you.
:: Mark
When I jump from Navigation to Media for example, the mute button toggles and sound mutes. I had this already on the 4.1. This occures almost every time I jump to the media screen from somewhere else. I have an external USB soundcard if that matters.
