Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 75
Thread: Centrafuse RC4.2 Bugs
  1. #51
    Low Bitrate predator1's Avatar
    Jun 2005
    Germany
    Quote Originally Posted by veetid View Post
    will get this fixed...
    david
    great, thanks.
  2. #52
    May 2006
    Seattleish, WA
    Hey David;
    I asked AlienEclipse if I could have a look at the files and try to help.
    I took a quick look this morning, and given the time diff from here to NZ, I figured I'd post up what I found while AE's sleeping.
    I'm pretty sure I know what's confusing CF. From the headers, it looks like AE is using iTunes to encode which seems to be using v2.3 of the ID3 tags (weird, but maybe it's an older iTunes?). Anyway, I'd bet you're only looking for v2.4 tags. The v2.3 tags are max 3 characters, so (for example) you'd see "TRK" instead of "TRCK". I think you'll need to search for both.
    The v2.4 tag frames are defined here:
    http://www.id3.org/id3v2.4.0-frames.txt
    ...and the v2.3 tag frames are defined here:
    http://www.id3.org/id3v2-00.txt
    :: Mark
  3. #53
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by midiwall View Post
    Hey David;
    I think you are right, but the other way around... Someone posted in the main group that when they set their new iTunes 7 back to use 2.3 tags, everything worked fine... so when iTunes upgrade to version 7 they went to 2.4 tags, which I don't have support in for yet...
    I will add it...
    david
  4. #54
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    Yes it was iTunes 7.0.2 (latest) that the files were done in.
    Huge thanks Midiwall!!
    David, you and Midiwall are welcome to keep those mp3's if you like. I will be removing the ftp access in a few days.
    So whens 4.3 coming out. I need it bad!
    Please don't release it without id3 v2.4 support.
    <EDIT> Just going to use iTunes ID3 tag version changer.
    We are, will have and forever will be...
    But not tommorrow!
  5. #55
    Jul 2003
    Sweet. I've converted my mp3 to id3 v2.3.
    No CF is working like it should. IM SO HAPPY!!
    Also i noticed if i select an album and click the big play button, the HD playlist count goes to 1 like it should. It seems not work properly if you build up a playlist using the + button and then clicking the tick (ok) button.
    But not tommorrow!
  6. #56
    May 2006
    Seattleish, WA
    Quote Originally Posted by AlienEclipse View Post
    Now CF is working like it should. IM SO HAPPY!!
    Kickin'!
    Thank's for getting this fixed up David!
    :: Mark
  7. #57
    Kickin'!
    You were right, I just downloaded iTunes... They are crazy over there...
    It is the exact oppositte as I thought!
    iTunes7 uses ID3v2.2.0 - very very old stuff, obsolete and not used by anyone! NOT ID3v2.4.0 or even ID3v2.3.0.
    So iTunes uses the 3-digit tags (like 'TT2' etc.)...and they even use a 'wrong' ID3v2 frame size now ;-)
    Guess this time the folks at Apple have 'downgraded' their version for some unknown reason! Nothing uses 2.2 tags, it was the worse standard that came out, 2.3 came out pretty quickly and 2.4 works great too...
    However I can fiddle a bit with it to make it work in the next release I think...
    david
  8. #58
    Newbie theflygtiguy's Avatar
    Sep 2006
    Bellevue, WA
    I am still seeing the issue with XM.
    when its enabled with the XMPCR and i set the port that its on with the line in Device... it echo's like crazy, over and over. every button i push echos more and more, and then the second that i disable the XMPCR, it stops doing it... this has been the same for me in every release so far.
    PLEASE let me know what i can provide you to get more information on whats going wrong here.
    Audi A8L
    CENTRAFUSE
    EN15000, 1g DDRII | 200g Media | Bluetooth
    Rear Camera | Dvd | Edge | Nav | Internet | XM
    www.mkippen.com
  9. #59
    May 2006
    Seattleish, WA
    Quote Originally Posted by theflygtiguy View Post
    This is a known issue, David hasn't worked on the XM stuff for quite a while.
    Head to the Mixer, then on the Levels panel, turn down the level of the XM input on the right side (not the output level on the right side). This should kill the echo. If it doesn't, then restart CF, make sure that input level is down, then do _NOT_ hit PAUSE while in XM (as indicated by the track time number at the top of screen counting down in negatives). If you do, then restart CF to remove the echo.
    :: Mark
  10. #60
    May 2006
    Seattleish, WA
    New small issue...
    • Set your startup module to something that's not on the first CF page.
    • Restart CF
    • Startup module loads correctly
    • Exit module
    • Note that CF is NOT on the page that contained the module, but is instead on the first page
    Not a big deal, but it's a bit "disorienting" as you start to move around within CF.
    :: Mark
  1. Centrafuse RC4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-18-2006, 03:10 PM
  2. Centrafuse RC3.1 Bugs
    Last Post: 10-06-2006, 05:11 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 07:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
