Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 75
Thread: Centrafuse RC4.2 Bugs
  1. #61
    Dec 2006
    Failed to load resources from resources ... etc
    XP Home (minimized, nLite), Dutch, Dotnet 1 till 3, PIII, 666, 250Mb, latest CF, default skin
    At first got the error when trying to build a library
    Lowered the amount of files, error happened a little while after building the library.
    Saw on the forum the same error appeared in 3.x and had to do something with viz ? Didn't know what was meant exactly, but got rid of the buttons I don't need in the main. Surprise was great when I was able to build the library, and play for more than 2 hours.
    Funny thing is, I played around with CF for a while BEFORE I tried to build the library. I played around with the settings for the navigation, no error came up, and this took me a couple of hours.
    There's one thing I'll try (cuz CF didn't give any error at all at my other machine, an AMD64 3400 though), reinstall the whole windows bunch (FULL) and stick to dotnet 1.1. See what it gives, won't be for today I suppose.
    Any idea is welcome
  2. #62
    Sep 2005
    I've had to reinstall CF a couple of times since RC4.2 was released. After a day or two of use, it brings me to the Setup screen again and I have to reinstall to get things to work.
    I'm not sure if this has been reported, but everytime I load my entire music library (about 1450 songs now), and restart the computer, most of the songs disappear from the playlist. The number of song still present in the list after a reboot varies between 50-250 songs.. It almost never resumes the actual song that was playing either.
  3. #63
    Dec 2006
    Red face
    Quote Originally Posted by nessie View Post
    [....cut]
    Any idea is welcome
    ok, don't know whether this is uselfull or not,
    installed XP Home Dutch, full, only 1.1, mapsource soft and that's about it, it works like a breeze
    so apparently I removed something critical with my nlite version ... question is: what ?
    cheers
  4. #64
    May 2006
    Seattleish, WA
    There have been a few discussions about nLite versions, and the net result is that CF is hooked into enough stuff that it's not really worth the headaches to figure out what you can get away with ripping out.
    Thee last time this was mentioned, someone piped up saying that he's been able to strip something out, but he didn't offer up an nLite config to share.
    Bottom line, I think 99.9% of the CF users are running a full install.
    :: Mark
  5. #65
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    My last ISO was down to 333MB including ~50MB of drivers. and it works fine with CF 4.2.
    I'm still working on getting it down.
    We are, will have and forever will be...
    But not tommorrow!
  6. #66
    Dec 2006
    Smile
    Would you be so kind to provide me your conf-settings (supposed you're using nLite) ?
    I might compare with mine then I suppose,
    Thanks in advance,
    cheers
  7. #67
    Jul 2003
    Thanks in advance,
    cheers
    Sure. you'll need to rename it by removing the .txt
    EDIT:
    This is for the latest nlite 1.2.1
    I started with XP Corp with slipstreamed SP2
    RyanVM Integrator:
    RVMUpdatePack2.1.4
    RVMAddonsDX9_1.0
    Boooggy_WMP11Addon
    Attached Files Attached Files
    But not tommorrow!
  8. #68
    May 2006
    Seattleish, WA
    Quote Originally Posted by AlienEclipse View Post
    Right on dude... WELL DONE.
    I thought you had given up on this a while back... Obviously I was wrong!
    :: Mark
  9. #69
    Jul 2003
    Its a long and painfull process, but i'm getting there.
    But not tommorrow!
  10. #70
    VENDOR - Centrafuse veetid's Avatar
    I have updated the threads...
    Here they are.
    RC4.3 Release Notes
    Centrafuse RC4.3 Release Notes
    Known Issues
    Centrafuse Known Issues
    All the major issues have been fixed... Still working on the HQCT some and trying to fix a couple of the issues listed under "Known Issues being looked into", I was able to remove a couple from this list, but of course add a couple more at the same time
    I still have to double check some code, package the installer, and test it...
    I know about the serial expiration issue and I'm working hard to get this out fast, but a good release...
    david
  1. Centrafuse RC4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-18-2006, 04:10 PM
  2. Centrafuse RC3.1 Bugs
    Last Post: 10-06-2006, 06:11 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 08:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
