Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Centrafuse RC4.3 Bugs
  1. #21
    Glasgow
    Quote Originally Posted by veetid View Post
    I can't reproduce it, so it's hard for me to fix... been trying...
    david
    Got a funny feeling it may have something to do with me turning of prefetch data on boot and programs so its not saving all the information it should when shutting down.
    Will disable it and install 4.3 and see what happens
  2. #22
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    Well me GPS still does not work...
    I use Franson GPS gate, and have it set to com port 14
    I use this peogram because i use several programs with my GPS-unit.
    It works fine with all other programs...
    Could you test this?
    www.superchargedmiata.net - all about roadster lifestyle
  3. #23
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by lazy_g View Post
    I have used GPSGate and it does work... I have also tested and made sure it works with Xport3... Try XPort see if that works...
    I actually recommend those programs to people having hibernation GPS locking issues....
    david
  4. #24
    May 2005
    hmm that is wierd...
    Did you use gpsgate 2.0 or 1.10?
    i use 1.10
  5. #25
    i use 1.10
    Whatever the latest on the GPSGate website is...
    So I would assume 2.0
    david
  6. #26
    May 2005
    ok will try that... maybe that is the problem
  7. #27
    May 2006
    Seattleish, WA
    You might also see if you can push that COM port number down below 10. Windows' _internal_ support can be pretty flaky about dealing with "high" numbered COM ports.
    Head for:
    • Control Panel
    • System
    • Hardware
    • Device Manager
    • Ports
    • {your port driver} double click
    • Port Settings
    • Advanceed
    • COM Port Number
    :: Mark
  8. #28
    May 2005
    Quote Originally Posted by midiwall View Post
    Head for:
    • Control Panel
    • System
    • Hardware
    • Device Manager
    • Ports
    • Port Settings
    • Advanceed
    • COM Port Number
    Ok thanks that worked like a charm!!!
  9. #29
    May 2006
    Seattleish, WA
    WooHoo!
    Yeup... gotta love Windows not being able to count past 9.
    :: Mark
  1. Centrafuse RC4 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 10-18-2006, 03:10 PM
  2. Centrafuse RC3.1 Bugs
    Last Post: 10-06-2006, 05:11 PM
  3. Centrafuse 1.5 Bugs
    Last Post: 01-14-2006, 07:03 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
