Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 86
Thread: Centrafuse RC4.4 Bugs
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by ahew View Post
    I noticed that from the previous versions. It happens when you go too fast past the end of the song/video and then it just goes all over the place. This needs to be fixed up. David will there be some kind of progress bar put in place as well?
    I've tested quite a few times and I don't get that problem. Just wanted to know if you're using version 4.4? However, while playing around with this I did notice that sometimes if I selected an a single album/genre/artist the last song is still in the queue after I eject while that song is playing (audio stops). Sometimes the queue is even larger if more than one album/genre/artist is selected. David, I think that may be a bug coz it doesn't completely flush the queue sometimes. This doesn't seem to affect anything if you decide to load another list by pressing play, but if you decide to add a few different folders first and then play the queue, it won't be completely flushed and you will still have those songs in your queue although you thought you ejected them already. Also realised that if I was playing a list of songs and I went and deleted the queue, it doesn't stop playing and it doesn't delete my list in the Media panel. Geez I hope that all makes sense.....
    You need to add the folder/genre/song/whatever with the + button. when you've finished choosing all the songs, go to 'Playlist', then select 'Queue' and press the Play button.
    I will look into the Queue clearing issue...
    You don't have to go all the way to Queue and hit play, that is what the checkbox in the bottom right corner is for, auto start playing Queue again...
    It resets music for some users now, but that is a known bug...
    david
  2. #22
    Aug 2006
    Quote Originally Posted by veetid View Post
    david
    i see... i never even knew that! sweet!
  3. #23
    Mar 2005
    Pomona, CA
    -Lots of instances where I see the taskbar popup while loading/closing apps, etc. I do not want to hide the taskbar in CF settings as I frequently use JIT's "show desktop" app. It seems like CF isn't always on top as it should be?
    -Up and down scroll buttons in the web app don't work for me.
    -I noticed a 7-8 second lag/loading screen when opening the weather plugin once. Not sure how to reproduce.
    -Still some problems with the USB CD drive and the que count being off. I also noticed that one time it put the CD songs into the regular HDD playlist right after it downloaded the title/artist info.
    -DUN is still not dialing sometimes. It works flawlesly outside of CF by clicking a shortcut I have on the desktop, but CF sometimes won't do anything and/or show a blank loading screen with only a cancel button. In regards to this, is there a way to show us if the internect connectivity green light is from a wireless card or from our dun connection? A future feature, I know, but still worth mentioning.
    -Initial loading speed of the app is mediocre. It had improved greatly a few releases ago, and has gotten better slowly, but still isn't quite fast enough for my liking on what I imagine is a 'faster than average' micro atx system.
    -Also, phonecontrol is still just as buggy as ever. I guess I should chat with Zorro about those problems.
  4. #24
    Apr 2005
    Problems with multimonitor support
    I upgrade my Carputer with an ATI Radeon 9550.
    And setup cloning the main Diplay on the second displays on my Rearseats.
    Also i activate the Theater mode, which plays videos in Fullscreen on the second Display.
    That setup work like charme! But when i close the Video in Centrafuse, or switch back to Music, the Displays aren't cloned anymore on my Reardisplays. They show the last image of the Video, until it was stopped.
    I have to close / restart CF to clear the reardisplays.
    Seems the Video-overlay isn't closed when stopping the Video?
  5. #25
    Quote Originally Posted by kranze View Post
    I will check this out...
    david
  6. #26
    FLAC Jahntassa's Avatar
    May 2005
    Conyers, GA
    Okay, here's a new one. I ripped out my old CarPC and replaced it with a Dell GX260. Not too bad, the thing hibernates in about 4 seconds and resumes in about 6. (Yes, hibernate)
    Here's the problem. I'm using the onboard sound, which is, according to the drivers, an Analog Devices ADI 198x Integrated Audio. It works fine, all is well and good. BUT, if CF is even RUNNING at the time of hibernation, on resume I have no sound. None. I tried turning off acceleration in the windows control panel but still the same thing.
    If I go into windows volume control I can mute / unmute the line-in and get back my line input, but the WAV system is totally hosed until I do a full restart. I can be running other media players (WMP11, Divx6) and hibernate and it comes back up just fine. I didn't have this problem on my previous system, which I know is a different soundcard.
    What do you need to see to try to track this down? I'd like to avoid getting an USB soundcard just because i'm cheap.
  7. #27
    Quote Originally Posted by Jahntassa View Post
    try some new drivers... try to find some newer or older ones...
    david
  8. #28
    Mar 2005
    Pomona, CA
    This sounds EXACTLY like the issue I am having with my audiotrack prodigy 7.1lt soundcard. Every other media app, front end, etc works just fine... CF is the only program that stops the soundcard from working coming out of hibernation. It is very odd, but good to see someone having similar issues.
  9. #29
    Mar 2005
    Wiesbaden/Germany
    I bet CF is the only application on your computer using BASS Audio Library
    http://www.un4seen.com/ !
    May be try another application using BASS and see what happens...
    consider a .NET app for this test...
  10. #30
    Glasgow
    someone please tell me how to get the navigation voice to go off, i have set all the settings with no joy in all releases so far.
    Still got the problem of not saving track position and playlist count
  1. Replies: 13
    Last Post: 12-13-2006, 05:17 PM
  2. Centrafuse RC4.4 Release Notes
    By veetid in forum Centrafuse
    Last Post: 12-10-2006, 10:50 PM
  3. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 01:48 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
