Page 5 of 9 FirstFirst 123456789 LastLast
Results 41 to 50 of 86
Thread: Centrafuse RC4.4 Bugs
  1. #41
    Sep 2005
    Has anyone else been presented with the setup screen after using RC4.4 for a few days? Got it today, nothing else to do but reinstall... again
  2. #42
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    1) launch CF and go to settings-->audio/video
    2) set "visualisation display" to "display2" (you need to have 2 screens)
    3) go to media and play an MP3
    4) go to full screen vizualisation (the viz will be diplayed on display 2 and will display CF media player on display1)
    5) go to settings and put back "visualisation display" to "display1" (visualization is still displayed on 2)
    5) save changes (viz will go to fullscreen on display2
    6) NOW YOU CAN'T DO ANYTHING!! CF IS BLOCKED IN FULLSCREEN ON DISPLAY1
  3. #43
    Slovenia (EU)
    I can second the coucouillu's problem.
  4. #44
    Aug 2006
    hey david, had a problem with CF not switching and just freezing yesterday that occurred a few times when I did this:
    1) Play a media file (I loaded a DivX and also loaded an mp3 ie 2 playlists)
    2) Use the Media menu to select DVD
    3) Play DVD - all well
    4) Press the Menu button and select Media, nothing happens but you can hear the audio from the DivX/Mp3 and the DVD video/audio is still present
    5) Press the <- button to try and exit out. Again, nothing but each time you press the button the playlists switch from DivX to Mp3 (i could tell becaus the audio would change).
    6) Tried to stop the DVD altogether and all it did was Pause and Play the actual Playlist music/video.
    This problem didn't occur if I switch by going from Media -> Main Screen -> DVD (and the reverse). It only happened when using Menu.
  5. #45
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by ahew View Post
    are you using multiple monitors?
    How did you use the menu to go back to Media from DVD?
    david
  6. #46
    Jun 2005
    MD, USA
    i just notice that every so often if i have a visualization running it will freeze and centrafuse will stop playing music after the current track finishes up. then the whole system freezes and i have to cntrl alt dlt it then reopen centrafuse.
    it usually happens with the white wave type visualization. the one that looks really resource heavy. nothing happens before it freezes, it will just stop moving and then the above happens.
    i would think my system would be able to handle it ok. mII 10k with not a whole bunch of junk on it. the other visualizations haven't froze to my best recollection.
  7. #47
    Quote Originally Posted by tibby01 View Post
    I have gotten reports that one of the visuals can crash the system... I need to remove it, never happened to me and noone could ever remeber which one it was...
    It's probably code some bad code in it... Is it the first or second visual after the album art?
    There are only 4...
    1. one starts with a burst of color and almost seems like fireworks
    2. colored circles with lights that move into them and it adds tubes
    3. One looks like waves that fall down and then bounce up from the bottom and curve like waves
    4. one is a spiral that grows and shrinks
    I assume you are talking about number 3?
    I hope the descriptions make sense
    david
  8. #48
    Try and remove
    Acidspunk.svp
    corona.svp
    Remove both those files from the Visuals folder and see if it freezes on you again...
    I think it's one if not both of those...
    I plan on probably removing these two visuals in the next release because they both use a lot of CPU and I believe have some bad code in them...
    I will find some others, but stability is the utmost of course...
    david
  9. #49
    Aug 2006
    Quote Originally Posted by veetid View Post
    david
    hey david, just using a single monitor and i managed to go to DVD by changing the menu options in the settings.
  10. #50
    Nov 2004
    FRANCE
    I have the problem on both MII12000 and Jetway 7F2WE-2G-OC
    I have this from a very long time throught all RC versions. I thought it was a problem from my video drivers on my MII12000.
    Now i bought the jetway one (total fresh WinXP install) and the problem is still here.
  1. Replies: 13
    Last Post: 12-13-2006, 06:17 PM
  2. Centrafuse RC4.4 Release Notes
    By veetid in forum Centrafuse
    Last Post: 12-10-2006, 11:50 PM
  3. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 02:48 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
