Page 9 of 9 FirstFirst 123456789
Results 81 to 86 of 86
Thread: Centrafuse RC4.4 Bugs
  1. #81
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by jarred View Post
    This is with my CarPC, using a Snapstream Firefly remote sending keyboard shortcuts to change the volume. I do have a touchscreen and right click is enabled.
    The volume does work when this is occurring, and the bars increase and decrease. However, once the error message comes up it stops responding.
    if you disable right click it should fix your problem, the right click event is firing and causing centrafuse to not get a mouse up event to stop the volume thread, which I guess is going forever and causing the error...
    did you ever get the error with your remote?
    david
  2. #82
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    Quote Originally Posted by veetid View Post
    david
    Actually, I'm not controlling the volume via the touchscreen, only the remote. This is happening when I use the remote to control the volume. Actually, I cannot use the touchscreen to control the volume, because I'm using the Nexus skin, which does not have volume control on the screen.
  3. #83
    I will check it out...
    Do you have the remote send the CF volume hotkeys or just control the windows volume?
    david
  4. #84
    Sep 2000
    Stockton, CA USA
    david
    It sends CF Volume hotkeys.
  5. #85
    Dec 2006
    With Realtek HD audio sound, when you press "Media" on the main menu the volume will automatically go all the way down to ""min"" and you cant hear anything and have to turn up the volume. One you turn up the volume and exit the Media and go back into Media again the problem still occurs.
    RTL8201CL is the audio chip. and its on a Asus k8v-mx motherboard I have installed the latest driver from realtek and still no luck. At the moment i have a pci sound card in it which is working fine.... any help???
  6. #86
    Quote Originally Posted by Alfredbra View Post
    been fixed in upcoming RC4.5
    david
  1. Replies: 13
    Last Post: 12-13-2006, 06:17 PM
  2. Centrafuse RC4.4 Release Notes
    By veetid in forum Centrafuse
    Last Post: 12-10-2006, 11:50 PM
  3. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 02:48 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
