Page 1 of 9 123456789 LastLast
Results 1 to 10 of 86
Thread: Centrafuse RC4.4 Bugs
    VENDOR - Centrafuse veetid's Avatar
    Post all bugs found in RC4.4 here.
    Read the release notes for all the changes and additions in RC4.4
    Release Notes
    Centrafuse RC4.4 Release Notes
    First check to make your bug is not already known.
    Centrafuse Known Issues
    Request features and additions in the main forum, not this thread.
    Make sure that we are not already planning on adding your requested feature or addition.
    Centrafuse Future Features
    david
    Aug 2006
    Navigation
    Ok I have some issues with the navigation part of the software, I was using IGuidance using the plug in and it work great but the sound issues with it kinda of bother me, so I decided to use destinator the gps sw that you guys bundle witht he software, first of all the maps keeps calling out yards instead of feet, miles are coming up but just that, also when goign on a route and try to change a song it lags for ever takes like 30 seconds to change the song also when you try to do anything else it takes long so its just not the track change but volume, trying to go to the main menu, etc etc, is there something out there to fix this issue or am I doing somethign wrong.
    Quote Originally Posted by emenny81 View Post
    I don't have these issues on my M10000... Might be your maps, what are they? What are the specs on your machine...
    david
    Aug 2006
    I have an m10000 with 1gb of ram, 30gb HD, usb cd rom, I use the bu353 usb gps module, as far as I know I have the latest drivers because Im able to chooose the native resolution for the monitor even though the lilliput doesn't take it but that another story, its weird, the maps well I downloaded the maps from bit torrent , Im doing it like that so I can test before I buy, I've used IGuidance because that's the one I bought but like I said I wasnt using centrafuse till I had issues with my other front end, so far this one has lots of features that in the future I can to implement, its weird, but yeah It lags big time Im not running centra fuse on shell, should I do that ?
    shouldn't make a difference... If you disable GPS COM port and just load GPS without it receiving data does the lag stop?
    david
    May 2006
    Seattleish, WA
    David;
    I looked at "ahew"'s MP3 files, these were a set that he was reporting as showing "Unknown Artist". A few things popped out at me:
    • For the sake of building a list of "encoders with known weirdness", it looks like they were encoded with Lame 3.93.
    • They have both v2 and v1 tags. Maybe that's confusing CF?
    • They're v2.4, did you get that in? I'm lost as to what you original supported versus were looking to back support for iTunes.
    • Lame is using the TENC flag to list encoder specifics. It's the first flag and it might be throwing you off.
    • There are multiple PRIV fields which is legal to do, but could be confusing.
    :: Mark
    Quote Originally Posted by midiwall View Post
    David;
    Should be working with 2.4 files... I just added back in if I don't see 2.4 go back and look for 2.2, which is what iTunes had moved backwards too for some reason...
    those should read... I will check it out
    david
    May 2006
    Seattleish, WA
    From your Known Issues in RC 4.4, I don't see:
    • Add (music/video) folders dialog broken. e.g. I want to add "c:\data\music":
      • Select Add Music Folder
      • Click "c:\"
      • Click "data"
      • Click "music"
      • Click "save"
      • Nothing happens
      I later found this was due to not having any files in my selected directory, thus your list dialog wouldn't let me click into a empty list item thus not allowing me to click "save".
    • XM list entries have confused data elements. e.g. Channels "41" & 48" both reporting as "Bone Yard" (they're not); "41" reporting as class = "Christian" (it's "Rock"); title of track on 48 showing on 41; etc. Will clear (i.e., display will be correct) after one or two refresh cycles.
      This has been around for a LONG time.
    • XM isn't saving Last Channel. It's always defaulting to "1".
    • VERY long "start times" on large MP3 tracks. My original bug report was:
      I have a number of electronica tracks as MP3s, most are 80meg in size, some are over 100meg. When selecting one to play, I get the "Loading" banner for quite a while, (20-30 seconds on a 2ghz machine with 1.5gig of RAM) before the track starts to play. What are you "Loading"?
      WMP starts the playback of any of these tracks in under a second.
    • "Clear Buffer" error on start-up
      Object reference not set to an instance of an object.
      at centrafuse.main.clearBuffer(Boolean play)
      at centrafuse.satradio.tuneChannel(Int32 channel)
    • CF shows wrong page after startup module exits
      • Set your startup module to something that's not on the first CF page.
      • Restart CF
      • Startup module loads correctly
      • Exit module
      • Note that CF is NOT on the page that contained the module, but is instead on the first page
      Not a big deal, but it's a bit "disorienting" as you start to move around within CF.
    :: Mark
    Your first issue is most likely because you have single click on, I know about the single click issues... Or is this in double click mode too? I listed single click issues in just the media manager, but there are issues in file browser too...
    All XM issues I'm not working on right now... The entire stall with XM is not because I can't fix it up really quick, it's because I'm still working with XM... XM just ordered a Cease and Desist to even Xtreme PCR, which wasn't even doing anything bad like TimeTrax... My contact this morning said they will be sending Cease and Desist letters to any and ALL software that works with any XM device hooked to a computer... We are working on a contract to allow Centrafuse through the use of something to work with XM... this is why I don't work on it... I legally can't right now... It was always in question and we have worked with XM, but as of now they decided to try and stop ALL XM use on PC hardware...
    I will look into large mp3 problem....
    As for the startup page, that button is a main menu button and that is just how it works... your logic is not a bug, but more a feature and I'm not sure I agree that it would make sense...
    I updated the Known Issues Thread:
    david
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    It's an issue in double click as well, but the issue presents itself a bit differently. In double click, when you get to C:\Data\Music (and the folder's empty), clicking "SAVE" will pop a dialog box of "Nothing Selected".
    All XM issues I'm not working on right now... I legally can't right now
    ARGH. Okay, but is that "LOADING message after hibernate and HANG" actually an XM bug or is it that CF shouldn't be trying to reload the module after hibernate? If we/you look at it as a core CF issue, then you'd be outside of boundaries the C&D order.
    That one bug is _KILLER_ David.
    We may have a disconnect here... which "that button" are you thinking of? Here's a real world example... In a default CF install, set the startup app to be "Weather" which is a button on the second page. CF will load, then load Weather. When you exit Weather, CF is at the first page, not the page where Weather is.
    If that's a "feature", I guess I can see the logic either way. It just seems a bit off to be returned to a page that doesn't contain the module that you just came out of.
    Can you please put the "long start times for large MP3s" on there too? Thanks.
    :: Mark
  1. Replies: 13
    Last Post: 12-13-2006, 05:17 PM
  2. Centrafuse RC4.4 Release Notes
    By veetid in forum Centrafuse
    Last Post: 12-10-2006, 10:50 PM
  3. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 01:48 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
