can't reproduce this... I did make some changes in RC4.5 so hopefully it goes away, otherwise I will try to reproduce...
david
Ive heard of this issue before, but it is happening to me all of a sudden, when it was never seen before in my setup.
See attached screen. The square appears at the end of every single Album title. As you can see, the Access MDB file (from MAIN.DAT) does not have any strange characters at the end. I moved the cursor one space at a time, and there is no trailing character.
Any ideas?!
EDIT: Resolved! See THIS thread.
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
david
Iths happenning only on my home PC. CarPC does not exhibit this.
I think something triggered this to happen all of a sudden (!)
2002 Honda CR-V
I also have the squares showing up on some of my titles.
Progress:99% not 100% because theres always something to do...
Centrafuse on XP (lited)
EN15000
120GB 2.5" SATA HD
1GB DDR2 Ram
M2-ATX PS
Slot-Load DVD
BU-353 GPS w/Mappoint 2k6
DWW-700M
me too,
sqares on my home pc. dont have tried the last version in car, but is a 4.4 problem.
some Rippers use weird spacing...
Try deleteing the last word from the ID3 Tag..then Saving it...then re adding it and see if it helps
For Bootscreens click Here
2002 Honda CR-V
i have foudn that this is a font issue as in if you dont have the correct installed font or CF dosnt support that font thats when u get the squares.
2002 Honda CR-V
yes that is what i mean i have seen it be because of improper font, but maybe cause of the extended id3 tags as well.
