Page 12 of 17 FirstFirst ... 234567891011121314151617 LastLast
Results 111 to 120 of 162
Thread: Centrafuse RC5 Bugs
  1. #111
    Jul 2006
    there is an issue with the usb device counter. if you plug and unplug the stick several times while CF is running, the counter goes up each time, but ejecting the playlist has no effect. im not sure what the purpose of the counter next to the usb device even is....
  2. #112
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by hari-bhari View Post
    I will look into this, but when you pull the device out it should remove the counter number, same with eject...
    this is if you had multiple USB ports and plugged in two USB devices and had both playlists loaded, you can click the button and rotate between the two of them...
    The number shows how many are loaded...
    david
  3. #113
    Low Bitrate Flappy's Avatar
    Jun 2004
    Netherlands
    There is no problem with selecting the favourites, the star will stay. But when i open the music library, and select 'playlists', and then 'Favourites', the playlist with all my favs won't open. It did work all previous versions.
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
  4. #114
    Quote Originally Posted by Flappy View Post
    does it do the same in double click and single click mode?
    if you just highlight favorites in singleclick mode and hit the large play button on the left does it load them?
    if you hold down the star icon on the media player page for 2 seconds do your favorites load?
    It might just be a single click issue, but I will check it out...
    david
  5. #115
    Variable Bitrate AlienEclipse's Avatar
    Jul 2003
    Dunedin - New Zealand
    David, how are you going with RC6? How many of the 40 known bugs have you got through?
    We are, will have and forever will be...
    But not tommorrow!
  6. #116
    Quote Originally Posted by AlienEclipse View Post
    11 left...
    plus about 7 phone related bugs...
    I will try to update the threads and a make a progress report...
    I aiming for by the end of the weekend, but not promising anything
    The next release will simply be Centrafuse 1.01, no more RC or Beta...
    It will still go through another round of testing and might not be ready until 1.02, or 1.03....
    david
  7. #117
    Jul 2003
    Quote Originally Posted by veetid View Post
    11 left...
    david
    Excellent, good to see your almost at your first release.
    Just out of curiosity when did you first start thinking about doing your own front end and what inspired you to do so?
    But not tommorrow!
  8. #118
    kinda of topic, but will give one post...
    Had a computer in the car for years and always wanted to do something to make it better... started with just a laptop in the seat, progressed from there...
    about 2 years working on the front-end, but did a complete rewrite and started taking it serious about a year ago...
    david
  9. #119
    Jun 2004
    Netherlands
    david
    I use single click mode all the time.
    When i hold down the star icon for 2 secs, it loads the favourites perfectly. So the problem is kinda solved now, thanx.
    AsRock AM2 dual VGA
    AMD Sempron 3000+
    512MB DDR
    3,5" 80GB harddrive
    Liliput 7"
    TFT 15"
    M2-ATX
    0% [OOOOOOOO-] 100%
    My install
  10. #120
    so they are getting stored... not sure why you can't click into favorites and see them...
    does it create an error.log file for me to look at? I just tested in single click mode and it pulled all the favorites up...
    Also note, even when in single click mode you have to double click favorites in the Playlist section to go into it, or use the forward arrow...
    This is because you need to be able to highlight Favorites and click "-" to remove them, especially with the Queue...
    maybe you just didn't go into the folder...
    david
  1. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 02:48 PM
  2. Centrafuse RC4 Bugs
    Last Post: 10-18-2006, 04:10 PM
  3. Centrafuse RC3.1 Bugs
    Last Post: 10-06-2006, 06:11 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
