1)when resuming from hibernation, the music does not resume until you touch the screen.
2) when playing a video, and plugging in a usb jump drive with a picture on it, the video continues playing. however when you eject the jump drive or pull it out, the video somehow backtracks about a minute or two....
When on a route, it will show a list of up and coming turns on the right of the screen, this cannot be switched off once activated, and if you press the close button it just re-appears next time it prompts you for a moneuver.
When you say D7 is an 'UPGRADE' does that mean it will be a $£$ extra or an UPDATE? This should be included in the GPS version of CF as the NAV section is the weakest point of CF currently IMO. People have moaned about Destinator since version 3.0, lets hope D7 is noticably better![]()
Also have you gotten anywhere with the POI/Speedcam warner?
Any news on making CF capture more than one window (with a different window name), and maybe also dialogue boxes which may or may not appear from an embedded app? You said you might look into this a few months back.
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
you can disable auto show turn by turn dialog in navigation settings, it's an option...
There will most likely not be much of an upgrade price, hopefully just sent down a better engine through the updater... if so it will be minimal I'm sure, up to Destinator...
I have no issues with Destinator, I actually have done US cross country driving and had it perform better than many/most navigation softwares...
maybe it's your maps or region? I do miss street names in 3D mode, but that's about it... It's already been added and I have the alpha for D6/D7 and I have seen it working, looks nice!
still working on the speedcam... I have all the favorite importing working and reading most all file formats, just need to get the hide/show on map and alert working...
I have not looked much more into external apps...
current plans are fixing bugs and making this application stable so it can be offered to the users that want it, then I will get right back to adding features and posting the next generation Beta's...
I have so many ideas and things I want to add I was forced to finally put a stop or I would be adding features for the next 10 years the way my brain works
have to finish one at one point, then I can start adding features again and I can't wait!
david
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
I hope this ain't mentioned yet, but if i play a DVD, i have 1 small problem.
When the DVD menu starts, you have to click on 'play movie', or 'select chapter', or something like that. When i tap one selection, the DVD controls pop up, so there's no way to start the movie. This was no problem before, when there was double-tap.
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Dont know if this was an option or not...but when in the DVD screen...there are no button sounds...for me i like this because when viewing DVD's or videos you have to turn the volume up louder then mp3's...and the button clicks and beeps are too loud...can you turn off the button clicks for video's as well...
never thought about it... basically because you have your volume so load for your video, the button clicks are way too load...
maybe I can make button click volume a percent of the current volume so it goes down as the volume goes up?
You should also still be hearing it in DVD, I will look into this...
david
