Page 14 of 17 FirstFirst ... 4567891011121314151617 LastLast
Results 131 to 140 of 162
Thread: Centrafuse RC5 Bugs
  1. #131
    Apr 2006
    Bolton, UK
    First of all let me congratulate you on a fantastic frontend.
    I have noticed one small problem. I don't know if it's specific to my setup (although I don't think anybody else has ever mentioned it). The problem is my cam which is connected to the composite input on a Hauppauge PCI TV card.
    After setting up the cam video source to composite in the settings menu, it works perfectly. When I reboot the system, I need to enter the settings menu again and reselect the composite input again before the cam works. The setting itself has been remembered - I just need to enter the cam menu, press the save button, then it all works perfectly (It's as if the act of entering the menu or saving the config "initiates" the device)
    I hope this makes sense and I look forward to your reply,
    PJ
  2. #132
    Jul 2006
    if you've got a dvd with some scratches on it, or something that would cause it to freeze, cf also becomes unresponsive. i can't exit out of the dvd player or use the menu button or anything.
  3. #133
    Newbie kftqq's Avatar
    Aug 2006
    Galway, Ireland
    I found a (minor) bug the other day...
    Set CF to run as shell, and set the 'Main Page Exit Button Action' to 'Exit Menu'. When you select 'Exit' from the exit menu, CF exits but does not load windows explorer shell. If you leave the 'Main Page Exit Button Action' as 'Exit', it works fine. I don't remember this being a problem in RC4.4, but I haven't had a chance to check it for sure... I've checked this on my laptop and it's the same story here also....
  4. #134
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    I've only just gotten my car back from the garage after the latest theft attempt, and have gone straight from RC2 -> RC5 (with a full uninstall of course). Apologies if some of these have already been brought up.
    So far I've found the following bugs:
    - The sticky volume control has come back occasionally. You start using it and when you stop using it the volume control stays open, but does not change volume, can be fixed by hibernating then unhibernating
    - There is still some stuttering occasionally on the voice directions from destinator, it's kind of like what you get in Half Life 2 if you have a crappy system and old soundcard drivers, but I am running the latest sound card drivers
    - Switching to the media screen still mutes the sound.
    - Still no control over the rears and centre/sub volume sliders
    - Still resuming from hibernate at full volume. A single tap of volume up or down sets it to the correct volume (plus or minus one notch, obviously)
    - One incidence of a "resource missing" error of some sort, telling me to check my setup. I couldn't get the exact message as it appeared behind the sticky volume control.
    Edit: Regarding the DVD volume thing mentioned a few posts above, perhaps each module could be given it's own preamp setting so that you can adjuse the volums of each module relative to each other. Similar to how Windows Vista is doing, and how my ancient Pioneer CD head unit used to to.
  5. #135
    Apr 2005
    Quote Originally Posted by hari-bhari View Post
    1)when resuming from hibernation, the music does not resume until you touch the screen.
    2) when playing a video, and plugging in a usb jump drive with a picture on it, the video continues playing. however when you eject the jump drive or pull it out, the video somehow backtracks about a minute or two....
    Same for me...
  6. #136
    Jul 2006
    not sure if this was brought up already, but when I receive a call through phoco, it displays the incorrect caller ID. it seems to be displaying the caller ID from the LAST call instead of the current one. All other features work fine.
  7. #137
    Newbie SUNAJ's Avatar
    May 2006
    Denmark
    Playing DVD and phonecontrol
    Hey again Dave
    Now when I got the DVD to work in CF 5.0, I tried to test different CF features.
    Ran across a problem ore a bug.
    While playing a DVD I made an incoming cal to my phone. The DVD isn’t muted (sound isn’t muted) ore if it’s possible to pause the movie.
    I have set the phonecontrol switching to headset at incoming calls, using my VIA EPM M1000 onboard soundcard.
  8. #138
    Newbie mJrO's Avatar
    Jun 2005
    Portugal
    few issues i have with this release of CF:
    - sometimes, after resuming hibernation phonecontrol and gps wont work properly (gps acquires satellites, but doesn´t move on the map).
    -Phoco - when resuming hibernation sometimes it can't acess inbox, received calls, etc
    - touchscreen and audio (this one wasn't present on previous releases). when my touchscreen is connected sometimes audio wont work (if i press any CF menu using the touchscreen) if i keep pressing other menus or options audio will come back. (my touchscreen is a cartft mm450 - same as mm400 but with more backlight)
    2005 S40 2.0D - Sport Body Kit
    Ipod 100%
    Carpc 95%
  9. #139
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by mJrO View Post
    not sure about your touchscreen issues, those sound strange and shouldn't have anything to do with Centrafuse...
    your GPS COM issues will most likely be fixed with programs like XPort or GPSGate...
    david
  10. #140
    Sep 2005
    Pomona, CA
    I noticed that on the GPS, the info seems to always show speed after coming back from hibernation. Isn't it supposed to remember which info you chose before going into hibernation?
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  1. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 01:48 PM
  2. Centrafuse RC4 Bugs
    Last Post: 10-18-2006, 03:10 PM
  3. Centrafuse RC3.1 Bugs
    Last Post: 10-06-2006, 05:11 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 09:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
