Hey David, still no luck on the LCD issue for me. my HD44780's are both wired up using the usual method, and they work fine with LCD center, but not with CF.
if there is a possibility that the
wiring schematic I used for both of mine is different from the one you used to wire your own, would you be willing to post the wiring schematic you used for yours?
I will strip one of my lcds down and start over with a new lpt cable and follow your schematic. this will rule out the possibility that the wiring is at fault, and we can potentially get to the bottom of it.
I am really looking forward to finally having my sweet blue lcd running in my car.
so keep up the good work, and get back to us with your wiring diagram ok?
thanks in advance.
