Page 6 of 17 FirstFirst 12345678910111213141516 ... LastLast
Results 51 to 60 of 162
Thread: Centrafuse RC5 Bugs
  1. #51
    Constant Bitrate AngryMan's Avatar
    Aug 2005
    Lewiston, Maine
    OK David, Ill send you one of mine. they are not in pretty little cases so the wiring on them is easy to examine. Ill even box it up right now just PM me an address to mail it to.
    .______
    / '__|__\____ VW CarPC project
    \(o)_____(o)/ Full Spead Ahead!
    Props to my Sponsor, Summit Adventure Systems Mobile Climbing Walls
    www.summitadventuresystems.com
  2. #52
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Very difficult to reproduce.
    Sometimes (I think after hibrenate wake up) if you change skin when reading a video, the video goes to fast forward alone.
  3. #53
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by coucouillu View Post
    It doesn't work for me on 2 machines (Jetway 7F2WE-2G-OC and Fujitsu Pentium 4 2.6GHz HT).
    It doesn't work if your setteings are :
    Settings-->General-->Startup location-->Main menu
    but if the settings are :
    Settings-->General-->Startup location-->Media its works!
    weird... If I exit and I was playing media, radio, or sat radio it always starts the music back up no matter what my section is...
    I will look back through the code and try to reproduce...
    david
  4. #54
    On Centrafuse Known Issues
    On my HTC TyTN Phoco program blocked after a few minutes (it doesn't exit but freezes with the little icon in green mode, Zorro would inderstand the green mode)
    with my tests it actually stops showing up in task manager all together and it has to be launched again, or phone rebooted...
    david
  5. #55
    Newbie LEiPiE's Avatar
    Aug 2006
    The Netherlands
    RC5 runs perfectly here... except (this is the bug thread ) the mp3 library seems to get messed up a little bit here. I've rebuild it, but get the same problem over and over: some artists have been randomly replaced by other names. They appear in the library list in the correct order, that is: based on the real name (erm ok, order is by the filename, doh )).
    So between Guns 'n Roses and J.J. Cale there's a sudden appearance of Air while in reality it's Hooverphonic... the two files that are by Air are correctly in the list though. In a list of 135 mp3s I now have 7 tracks where the artist's name has been replaced in some way.
    Rebuilding the library gives the same 7 errors.
    Haven't found a pattern: it's not the name of the track before it, it's sometimes an artist name that's ahead and sometimes behind in the alphabet.
    Also it's not that 1 artist name is completely replaced by another, though if it happens multiple times for the same artist it's by the same other artist.
    Multiple times the substitute name was the same by the way.
    I have not seen any other tag substitutions.
    See here for a list (that's one directory of a couple of dirs, there's only one other dir where there's only one substitution (MC Hammer by Earth & Fire (again!)).
    The artists are also not in the list if I browse by Artist (I usually browse by Music folder).
    What could this be? Willing to provide extra info if needed
    (and no: Earth & Fire is not Earth, Wind & Fire typed wrong... Earth & Fire was a Dutch Progressive Rock (later more pop though))
    (need to install the PC in my car again to see if satnav and such still work and if I have to complain about the resolution of the Cam plugin )
    CarPC: "Carma" (Car Audio & Route Management) (about 70% ready)
    P4 1.8GHz / 512MB / 4GB CF
    Asus TVFM + B/W camera
    15" touchscreen 1024x768
    BU303
    2x 100Ah
    reinstalling
    And all this in a Dutch 1972 Citroën HY van called "MurpHY".
  6. #56
    Quote Originally Posted by Alfredbra View Post
    cant get bluetooth gprs working through my phone. I have set up the bluetooth modem in windows xp, and can connect to the internet fine. When trying to connect using centrafuse it connects to the phone all ok, then trys to authenticate. Then after a period of time it just says error connecting. In the internet setup of centrafuse, all the details are correct the dialing number
    *99# etc. but cf seems to automatically put a 8 or more digit password in the password field even though there should not be one. if you erase the password it will come back again after closing down and reopening cf. Whether this has something to do with the problem i dont know.
    I am using an o2 mini xda phone (windows mobile 2003) and using the Widcomm bluetooth stack.
    This is on my list of known issues, DUN issues... The password is normal, I encrypt the passwords so people cannot see them if they open the text files, even a blank password has characters, that is not the issue....
    It works for me on dialup modems, but I have to look into issues with bluetooth dial up networking, that seems to be the issue...
    I will get it fixed...
    david
  7. #57
    I own destinator PN on pocket pc and have loaded the maps into centrafuse. I can navigate by city-street, but not street-city, postcode-street etc. I realise perhaps these maps may not be supported, but would be quite nice if somehow us australians could get it to work.
    Xport3 worked like a charm thanx!
    only D6 maps are fully compatible...
    david
  8. #58
    Jul 2006
    i am still getting the square block after my album names. i went through and deleted EVERYTHING from the id3 tags, including comments, year, etc etc. all i left was artist, title, album, track number, and genre..
  9. #59
    Raw Wave justintime's Avatar
    Apr 2005
    Quote Originally Posted by hari-bhari View Post
    What tag editor did you use? Some basic editors do not show you the extended ID3 tags. I think you might be deleting all the tags EXCEPT for the ones that really are causing the 'square' issue.
    Grab The Godfather and follow my instructions from this thread...
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  10. #60
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    If I go into setting via the side menu, edit nav settings... When I click save (settings) it then shows the map over the settings screen with the close button at the bottom, close button removes the bottom row of settings menu buttons and returns to NAV.
    It has done this since RC3 but I have been offline to post due to house move
    POI warning function also warns about every POI And no way to select what is warns for or what it says as a warning!
    Address lookups in NAV still take WAY WAY TOO LONG - 30seconds plus.
    Also still suffering the screen flashing issue on resume from standby and Hibernate. Clicking NAV when button is visible stops it - When all my hardware and PC in house is set up I'll do a video to show this problem for you
    It would also be handy IMO to have back and forward buttons on the playlist thingy on the left in Media player instead of just a back/eject button. You know, so you can skip forwards through playlists, not just go backwards.
  1. Centrafuse RC4.3 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 12-10-2006, 02:48 PM
  2. Centrafuse RC4 Bugs
    Last Post: 10-18-2006, 04:10 PM
  3. Centrafuse RC3.1 Bugs
    Last Post: 10-06-2006, 06:11 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
