Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 74
Thread: Centrafuse 1.1 Bugs
  1. #61
    Sep 2006
    1. This could be a bug or by design, when a web page is opened that has audio the audio keeps playing after exiting the web browser.
    2. I am using the warning screens. If a DVD is opened while at a stop it does not close the video when the vehicle starts moving. I will test the rest of the full screen and web applications later tonight.
  2. #62
    VENDOR - Centrafuse veetid's Avatar
    you are right, if you go into the features while stopped, they do not close when you start to move...
    this has been added to my list...
    not sure about the web browser... some like to listen to radio stations, etc... just hit stop for now...
    david
  3. #63
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    setup bug remains where it shows map over settings screen if you enter settings from drop down menu when in NAV screen.
    Getting address dialog open still takes way too long.
    Also, sometimes when in a embedded external app the return arrow doesn't respond until pressed twice in which case it then opens the exit menu (as I have it set), or you can click any other button and suddenly it will switch back to the main menu.
    There were some other things I noticed but they slip my mind now.
    How far off is the new Destinator David? Still fed up with PN as its not the newest or most efficient of route planners
    Satellite signal strength indicator on the nav screen would be useful, like you show mobile signal on main window.
    Oh, yeh, sometimes my day skin still uses night text colour on the top frame, which means white text on a pale grey back ground = pretty much invisible text
    And I think I am still having issues with music not resuming / playlist not loading properly on resume from standby, I have to go into Media, where it magically reloads the playlist.
  4. #64
    Aug 2005
    Quote Originally Posted by veetid View Post
    this should be saved, I cannot reproduce... Is this happening for anyone else?
    david
    I moved the weather downloading to a thread and I believe on some systems it is causing a stack overflow, therefore producing the error you see...
    It will be fixed in an upcoming very soon test of the updater...
    try removing the weather folder from plugins and see if you get the dialog again...
    david
    I removed the weather folder from plugins and it completely removed my weather plugin but i still got the message that kicked me out and it produced the exact same log in the error.log. So just look into, no rush for now.
  5. #65
    Sep 2005
    Pomona, CA
    The lack of gapless playback still persists. Is this something you were going to re-add, or is this really a bug. I would REALLY appreciate this being implemented.
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
  6. #66
    Quote Originally Posted by ShawJohn View Post
    I cannot reproduce this...
    I added settings to the drop down menu, go to navigation, then while map is showing I load settings using the drop down, then enter navigation settings and hit save...
    sometimes it will flash the map for a second when you hit save, but it doesn't stay up...
    can anyone else produce this? Is what I did how to recreate the bug?
    david
  7. #67
    Feb 2004
    I can't reinstall/install version 1.1 now. I hard shut down everytime I finish using my carputer and after two or three times of doing think the license files says its invalid even thou I am still within my 30 days. And i try and uninstall and reinstall but I keep getting the same error of invalid license file. I deleted all the files in the flux media folder and look through the registry is their any way I can reinstall centrafuse and not get this error?
  8. #68
    May 2006
    Seattleish, WA
    Quote Originally Posted by masher View Post
    ...even though I am still within my 30 days.
    When you install, are you clicking the "Trial" button at the registration screen, or are you using the serial number you can get from the Flux Media site?
    If you're not using a serial number, do this...
    • Head to http://www.fluxmedia.net/
    • Click on LOGIN (upper right)
    • Click NEW ACCOUNT
    • Fill out the stuff and click REGISTER
    • When you log in, you should see a section called
      ISSUED PRODUCT SERIALS
      Use that serial number when you install CF
    :: Mark
  9. #69
    Feb 2004
    Quote Originally Posted by midiwall View Post
    • Click NEW ACCOUNT
    I have tried both ways. Just using trial and then using the serial number that I have gotten from the site and they both give me invalid license when I try and load CF. Other then uninstalling and removing the flux folder is there anything else I need to do when I uninstall.
  10. #70
    masher: Is your date getting reset? Is your CMOS out or something? It has now locked out thinking you tried to break the trial past your date...
    This can happen mainly, or most commonly, with the date being changed or not getting saved...
    of course this won't be a problem with the final product, but this is very common with trials of all softwares...
    david
  1. Centrafuse 1.1
    By hodula1 in forum Centrafuse
    Last Post: 02-28-2007, 05:11 PM
  2. Centrafuse RC5 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 02-26-2007, 05:00 PM
  3. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 01:48 PM
  4. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 07:51 PM
  5. New Release CENTRAFUSE 1.1
    By veetid in forum Centrafuse
    Last Post: 01-18-2005, 09:17 AM
