Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: Centrafuse 1.11 Bugs
  1. #11
    May 2006
    Seattleish, WA
    Quote Originally Posted by veetid View Post
    open up your skin.xml file from the skin you are using and search for the text
    Regular
    It should return no results at all, if it does then you have a different skin.xml somehow than I do...
    Nope, it's not there...
    Code:
    c:\winapps\centrafuse>dir Skins\*.xml /s
     Directory of  C:\winapps\Centrafuse\Skins\Onyx WS Day\*.xml
    11/18/06  21:39         211,146  skin.xml
            211,146 bytes in 1 file and 0 dirs    212,992 bytes allocated
     Directory of  C:\winapps\Centrafuse\Skins\Onyx WS Night\*.xml
    12/04/06  21:40         211,145  skin.xml
            211,145 bytes in 1 file and 0 dirs    212,992 bytes allocated
    :: Mark
  2. #12
    Constant Bitrate jarred's Avatar
    Sep 2000
    Stockton, CA USA
    strange... This is with the udpate and 1.11 right? I did modify some code how the weather and the internet connection is detected...
    if you simply hit the volume key again after it gets stuck it doesn't close?
    I cannot reproduce this, I am hitting it really fast with and without internet...
    david
    Yes,
    It was with version 1.11. Hitting the volume up or down does not get rid of it. The dialog box does continue you display the volume changes, but does not go away.
    The setup error did eventually come up and an error log has been created...
    The bad news is now Centrafuse will no longer come up. It gets stuck on the spash screen at building controls.
    So I guess I'm stuck with roadrunner for now.
    Error Log Below:
    3/14/2007 9:32:03 PM
    Object reference not set to an instance of an object.
    at centrafuse.Music.loadSong(String filename, String songname, Int32 songindex, Boolean iscd)
    at centrafuse.Music.mp3next(Boolean nextclick)
  3. #13
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by jarred View Post
    Yes,
    Error Log Below:
    Try 1.1 and see if your issues go away... I believe most of this is being caused by bad internet detection code and lagging out the loading of the application...
    not sure about your volume issues, anyone else seeing this??
    david
  4. #14
    Sep 2000
    Stockton, CA USA
    david
    I had the same volume problem with 1.1, as well. I posted the error logs in the 1.1 problem thread.
  5. #15
    May 2006
    Seattleish, WA
    New one:
    • OBD won't catch the MIL lamp, nor read codes.
      I threw an MIL twice today (this is normal for me right now, I'm tuning) and both times CF never saw the lamp (i.e., the engine icon didn't light up), nor would it read the codes if I clicked on the engine anyway. It WOULD clear the code.
      In both cases I was able to read the code with another app in Windows, and another OBD device I have.
      This is an OBDPro USB box.
    :: Mark
  6. #16
    May 2006
    Seattleish, WA
    Another new one...
    • OBD will not reconnect after resume-from-hibernate unless it's the currently displayed module.
    :: Mark
  7. #17
    Slovenia (EU)
    Settings-> General (page:2): TIME ZONE, and MAIN PAGE CLOSE BUTTON labels aren't refreshed.
  8. #18
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    I cannot import speedcams...
    i tryed converting tomtom files to .dat and tryed freedrive .csv...
    It keeps on saying: "import failed, make sure the right map is loaded"
    I use destinator 6 maps for PDA (Version 2006.Q1.4155 - map of NAVTEQ)
    Or do i need different maps?
    www.superchargedmiata.net - all about roadster lifestyle
  9. #19
    Quote Originally Posted by lazy_g View Post
    I answered in the other forum you posted in... you have to have the write map loaded, check other thread...
    david
  10. #20
    Aug 2006
    david,
    ran the updater and then when it restarted the app it stated something like: "Failed to load resources. Please run setup again.". This was when CF was starting up and it stated "Building Controls" at the time. It took a very long time before the error came up. I couldn't restart properly either because I had no taskbar when CF exited.
    I tried rebooting the whole system to test and it's still doing the same thing however this time around it doesn't even have an error box, it just stays frozen on the screen with "Building Controls" and that's it.
    I'll see if I can get the error log but it will be a little bit tricky (probably need to load in Safe Mode).
    -EDIT- oops just read the Flux forum and found out about the internet connection issue. I'll see if this is the problem by disconnecting internet.
  1. Centrafuse 1.1 Bugs
    By veetid in forum CF Bug Reports
    Last Post: 03-13-2007, 09:11 PM
  2. Centrafuse RC5 Bugs
    Last Post: 02-26-2007, 06:00 PM
  3. Centrafuse RC4.3 Bugs
    Last Post: 12-10-2006, 02:48 PM
  4. Centrafuse 1.4 Bugs
    Last Post: 09-27-2005, 10:58 PM
  5. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
