Results 1 to 7 of 7
Thread: home screen clock and scrolling on CF4 and win 7
    Maximum Bitrate camo.b's Avatar
    Nov 2011
    this is one of my last little problems that i cannot seem to fix....in all screens where the time is displayed (above the network connectivity icon)if the time is say 10.45 and i have bluetooth connected...the time is cut short,meaning it will display 10.4
    next problem is scrolling down a menu,if i get to the bottom i cannot see or select the final entry,with a bit of fancy swiping and tapping i can just get it but its very janky....
    was thinking it might be a screen res problem but if i change it from within CF4 it make no diffrence whatever the setting.
    any hints as my system is getting close to perfect.
    Newbie 3MPS's Avatar
    Oct 2011
    Hey,
    I had the same problem with the time and it turned out to be the dpi setting making the text too big to fit. Have a look here, it's like the 13th FAQ. http://forums.fluxmedia.net/faq.php?faq=troubleshooting
    Good luck
    Sent from my evil apple using TapaCrash
    Nov 2011
    I have tweaked the dpi and everything else for using win7 on the 7" screen.will check now.cheers for that
    Sent from my GT-N7000 using Tapatalk 2
    Nov 2011
    That did it thanks.scaled the dpi back to 110% and it now fits and is still sort of large.just had no impact on the scrolling in menus....still cant get to that very last item....changed cf4 screen res to 640 x? Then others too...no good
    Oct 2011
    Glad it worked. For the scrolling, does it jump up when you get to the last item in the list? If so, this might help.
    http://forums.fluxmedia.net/support-...view-item.html
    I had the same problem and couldn't fix it (something about screen res) but changing to a new skin seemed to resolve it.
    If that ain't it then I have no idea man. Hopefully someone more knowledgable will jump in...
    Nov 2011
    Yep it worked with a skin change.swapped to fresh air and it is smooth as.just the colour looks too washed out for me to use.
    Nov 2011
    Update.....set windows and CF4 screen res to 640 x 480 or 800 x 600 on mine and everything works very well...total improvement on speed to very fast system now with all those pixles it DOESNT have to drive now.its fantastic now
  1. Scrolling screen
    By oroboros_ARR in forum LCD/Display
    Last Post: 05-29-2008, 01:08 PM
  2. GPS clock setting car clock
    By bes51659 in forum Road Runner
    Last Post: 04-24-2008, 06:03 PM
  3. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  4. DWW-7VGA Screen Scrolling
    By OzPaddy in forum LCD/Display
    Last Post: 03-03-2004, 09:29 PM
  5. On Radio Screen Clock Showing False?
    By ccsnet in forum ME Archive
    Last Post: 06-28-2003, 08:35 PM
