Page 2 of 8 FirstFirst 12345678 LastLast
Results 11 to 20 of 71
Thread: GPS window names
  1. #11
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    When embedding... you need to input what the window is called of the app.. so if u check the 3.1 prev of D3 then it says Destinator 3 - [Dest3.1] on the taskbar.. this is the text you put in. It goes for all programs. Just start up the app you want to embed and see what the actual name is on the taskbar. Its easy !
    cdr
  2. #12
    Low Bitrate microbionic's Avatar
    Aug 2004
    medina,ohio
    Quote Originally Posted by skydiver
    hay got it but i cant move the map
    if i move the map the screen doesnt refresh the pic untill i touch the zoom
    and if you close centrafuse it doesnt kill destinator or the destclient so the next time you run it it deosnt work unless you kill them both in memory first
    yes, i am having the same problem, this happens to both 1.2 and 1.3 prev
    CarPuter ProgressO meterO
    [+++++++++] 100%, 1Ghz Epia M,opus 90w, Earthmate GPS, 7 inch lilliput molded into dash, anything i forget?
    visit me on the web at
    http://gozips.uakron.edu/~cmk23/
  3. #13
    Constant Bitrate weekendowel's Avatar
    Jan 2004
    Stockholm, Sweden
    Quote Originally Posted by microbionic
    Also have this problem, when I drive around the map wont refresh until I use the zoombar, or use some buttons on the destinator app. It works when I run it standalone or embedded in FP.
  4. #14
    Nov 2004
    St Louis
    HELP! I can't seem to get iGuidance embedded in win98 install of centrafuse.
  5. #15
    VENDOR - Centrafuse veetid's Avatar
    GizmoQ: I haven't tried iGuidance in win98, but it's what I use on my XP machine. Did you set the window name to iGuidance? When loaded on win98 does the title of the application say someting different?
    david
  6. #16
    Nov 2004
    NYC
    NM's D3 frontend is awesome, but I can't get it to embed in centrafuse. I've tried all of the possible window names, but no dice.
    Destinator_3_-_[Dest3.1]
    Destinator_3_[Dest3.1]
    iGuidance and Routis can embed properly, now the question is which of the three is better? Someone replied to another posting, saying that iGuidance has more POIs, so how does it compare to D3?
  7. #17
    Check out this thread:
    destinator and centrifuse
    There are lots of people who have gotten it to embed. Pretty sure you need to go download the latest version... They are discussing all this in the above thread...
    david
  8. #18
    FLAC Skraggy_uk's Avatar
    May 2002
    Warrington UK
    Has anyone noticed that when using Ninja Monkeys D3 frontend, yes it can embed, but when you try to enter addresses, all sub windows open behind Centrafuse, rather than infront of Destinator. It does actually work properly if you disable "on Top" in Centrafuse, but then Destinator tries to load at it's default size, before embedding at it's correct size, and takes a second.
    4x4 in a turbo stylee.
  9. #19
    Skraggy: I am checking into this ontop thing. When I set everything ontop, it has adverse effects relating to embedded applications. Currently if you are going to be embedding applications, the safest thing to do is disable my ontop feature, until I get it worked out... It only shows the fullscreen D3 for a second and its only the first time you click GPS...
    david
  10. #20
    May 2002
    Warrington UK
    Yep, noticed. That is what I have done.
    It's weird while testing, as I'm using my desktop machine on high res, so Centrafuse sits in the top corner, with everything arround it, thats all.
  1. Emmbeding gps into frodo player window?
    By jermkesler in forum FrodoPlayer
    Last Post: 08-15-2004, 07:01 PM
  2. Window Tint's effect on GPS signal
    By MoFo in forum GPS
    Last Post: 07-19-2004, 06:08 PM
  3. Can the GPS mouse work in the back window?
    By carpcnoobie in forum GPS
    Last Post: 05-10-2004, 09:36 AM
  4. Replies: 3
    Last Post: 01-14-2004, 02:56 PM
  5. Replies: 0
    Last Post: 08-28-2002, 05:23 PM
