lerandell - what OS is that on? what is your CF "on top" setting? i've been trying to embed SA 2005 with no luck so far.
thanks
Just an FYI.
I have tested Street Atlas 2005 and as you would assume works just as the tested 2004 does.
Street Atlas 2005 / DeLorme Street Atlas USA%trade 2005 - Map File 1
Randell Kelly
thanks
2004 Toyota 4Runner Sport 4WD
Opus 90W, Epia M210K, Lilli 7" TS, 30GB, CDR/DVD Slot, PowerMate, Earthmate, 200GB Seagate 3.5", Verizon BroadbandAccess, CentraFuse, Valetine1 .....
XP Pro SP2.Originally Posted by roleary
Below are screen shots of the config and the software embeded into Centrafuse.
I have had the on top setting on both and it still works the same.
Randell Kelly
lerandell: I see you actually put the trade symbol in the GPS window name. I never got it working that way, but I guess it does. how did you get the trade symbol there? that is what I added the %trade for, it is searched for and replaced with the trade symbol at runtime. If you can place trade symbols in the setup then I guess I didn't need to do it.
david
I've had the same problem. I've got the window name correct (using the %trade) but when CF launches SA2005, it launches it in full screen. Also, when I exit SA, the Loading... screen is what CF displays and I have to use task manager to quit the program.Originally Posted by roleary
Want to:
Actually, I did put the %trade in there. I guess it converts it to the real deal when you go back into the setup after saving it.
try to copy and paist the line below into the setup and see if it works for you...
Randell Kelly
Thats weird.. I do see the SA2005 splash screen but it goes away. My GPS button never worked at all until I got the name right.Originally Posted by Bugbyte
What OS and SP level are you running?
Randell Kelly
The loading screen staying loaded when it can't embed, which causes you to have to kill CENTRAFUSE was a bug on my part... Its been fixed already...
Now that I think about it, it will convert it for you once you get it into the program, so it is working properly and you should initially use the %trade and if you ever need to use an & for anything use %amp...
david
Aha! I got it to work! Not sure exactly how but it embeds now. It may have had something to do with a stored route I had in it that changes the window name. I thought I cleared it out...but maybe not. In any case it's working now. Thanks for the help!
Want to:
Well, for what it's worth, I still can't get SA 2005 to embed.
Win 2k, SP4
