When you say Destinator 3, are you referring to Ninja Monkey's front-end?
Here is a list of the current GPS window names that have worked. I have not personally tested all of these, so let me know if there are any corrections. Please post any knew applications and window names you get to work.
Application / Window Name
iGuidance / iGuidance
Routis / Routis
Street Atlas 2004 / DeLorme Street Atlas USA%trade 2004 - Map File 1
D3 Front End / Destinator 3 - [Dest3.1]
I have written a small application for searching for window names. Download here:
http://www.fluxmedia.net/downloads/windownames.zip
Run the application you are trying to embed and then this application. It will list the main window titles of all running processes. You will see some blank lines, but these are just processes without window titles. Find your application and copy/paste it into CENTRAFUSE. Some special characters will not properly work. Currently I have put measures in place for one. Let me know if I need to add more.
Replace
® / %trade
Not sure... I will have to find out... Zorro gave me that window name and I am not sure what he was running..
david
im guessing it is.. it has 3.1 in itOriginally Posted by veetid
Not sure why there are slashes and underscores in there...
"Destinator 3 - [Dest3.1]"
works fine
Destinator 3 For PC! - http://www.map-monkey.co.uk/
Yes, referring to Ninja Monkeys frontend.
My post was:
Check your Window Title for D3 in CF. It has to be "Destinator_3_[Dest3.1]" (Spaces replaced with "_")
Skinning to go... VisualDesigner2!
That's still wrong - you missed the hyphenOriginally Posted by zorro
NM: updated it... thanks..
david
what file in the destinator frontend are you pointing it at ?
im still having problems
and are you using NM new beta frontend?
and if i run that name program it comes up with "Destinator3" & "Dest3Client"
no _ or - anywhere
hay got it but i cant move the map
if i move the map the screen doesnt refresh the pic untill i touch the zoom
and if you close centrafuse it doesnt kill destinator or the destclient so the next time you run it it deosnt work unless you kill them both in memory first
