Results 11 to 20 of 26
Thread: How-To embedding in CENTRAFUSE 1.3
  1. #11
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    Quote Originally Posted by anky1
    hopefully tonight i'll get to post the adv. version. if you want a headstart... download http://www.autoitscript.com/autoit3/ and an editor http://www.autoitscript.com/autoit3/scite/downloads.php
    I will show you how to use this app to get around special situations like variable windownames (timestamp of netstumbler).
    got it, can you help me now?
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  2. #12
    C4M
    C4M is offline
    Maximum Bitrate C4M's Avatar
    Apr 2002
    Sydney, Australia
    Quote Originally Posted by aoLhaTer
    Cool, snes9x works just fine
    The embedding is rather..."loose" though
    <image snipped>
    The embed window doesnt stretch to its max, you can still see the window behind
    I've noticed that the Media screen behaves in the same way. I guess the question should be "Is this attribute controllable via the XML for the skin?"
    C!
    http://carpc.riposte.net
    I reserve all rights in connection to each post I author, without exception.
  3. #13
    VENDOR - Centrafuse veetid's Avatar
    that's by design for this particular skin... you change that in the skin.xml if you wanted...
    david
  4. #14
    Apr 2005
    County Durham, UK
    Add in your previously compiled data. Also at this point you can rename the button, don’t choose anything to long though or it will not show up correctly. Other options at this point would be to let this application control another LINE, start full screen, or pause Music.
    Can you tell me what this means/does please?
  5. #15
    Newbie relidl's Avatar
    Jul 2004
    Yes i'm curious about the <linecontrol> option as well. Does this mean the volume of the application can be adjusted without altering the volume of the music?
    I have noticed that when this setting is left at default, when Routis starts giving navigation cues (eg turn right in 1000 feet) the volume of my music rises for the duration of the cue, then drops back down to its previous setting. I would love to be able to get rid of this.
  6. #16
    Aug 2004
    Black Hills, SD
    Quote Originally Posted by relidl
    The linecontrol tells what source to unmute. For example if you have something that using line-in it will unmute that source so you can hear it. It doesn't have too much to do with Routis volume. You basicly have to go into the Routis settings and set the cue volume to match the volume of wav in CF.
    Hardware: VIA Epia MS 12000, 512 DDR, 60GB HD, 7" Xenarc, GM-210, Wi-Fi, Bluetooth, Radio Xtreme
    Software: Centrafuse2, Phonecontrol.net, nLite, TopoUSA 5.0, iGuidance, Girder, Winc
  7. #17
    Nov 2005
    Belgium
    Im quite desperate so I hope this is the place for my topic.
    Im using CF1.5 with Iguidance europe 2.1.2 ... I use IGlaunch for skipping the warning message and works okay.
    I activated the full screen option in Iguidance and the windowname is also the same as the exe file I use for starting up.
    Now wenn pressing my external application through the buttun I assigned Iguidance starts in a window.
    Now I can easely switch between the CF buttons.. from media to home to ... only I can not use the command buttons within my Iguidance. " Menu and Volume button "
    Thx for helping me out and for any suggestion posted.
    Kind regards,
    Ben Monsieur
  8. #18
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Try running igLaunch separately and see if it causes the problem.
  9. #19
    Nov 2005
    Belgium
    It does work seperatly.. I just made a screen shot !
  10. #20
    Nov 2005
    Belgium
  1. Centrafuse 1.3 [beta2] Logos
    By tj!2k4 in forum CF Skins
    Last Post: 08-01-2005, 07:30 AM
  2. Release CENTRAFUSE BETA 2 (1.3)
    By veetid in forum Centrafuse
    Last Post: 08-01-2005, 04:13 AM
  3. Centrafuse 1.3 Bugs
    By rickster in forum CF Bug Reports
    Last Post: 07-26-2005, 08:51 PM
  4. Embedding in 1.3
    By CavityCr33p in forum Centrafuse
    Last Post: 07-18-2005, 09:16 PM
  5. Embedding FM PLugin into CENTRAFUSE 1.1
    By camsgs3 in forum DragonBTV's CarPC Plugins
    Last Post: 01-16-2005, 11:55 PM
