this may help for issues with special characters
http://www.mp3car.com/vbulletin/show...3&postcount=12
I will also be posting a more advanced version for embedding more tricky apps such as netstumbler
In this short HOW-TO we will embed a program Directly into CF
First we will need 2 things.
-Full path of the .exe to open
-The window name when you open this program
Once you get these 2 items open up your “external.xml” file
(C:\Program Files\Flux Media\CENTRAFUSE\System\External.xml by default)
Choose a button to place this application into (for this how-to we will just use APP1)
It should look like this
Add in your previously compiled data. Also at this point you can rename the button, don’t choose anything to long though or it will not show up correctly. Other options at this point would be to let this application control another LINE, start full screen, or pause Music.Code:<APP1> <PATH></PATH> <WINDOWNAME></WINDOWNAME> <DISPLAYNAME>App 1</DISPLAYNAME> <PAUSEMUSIC>False</PAUSEMUSIC> <LINECONTROL>NONE</LINECONTROL> <STARTFULLSCREEN>False</STARTFULLSCREEN> </APP1>
Save and close.Code:<APP1> <PATH>C:\program files\GPS\GPS.exe</PATH> <WINDOWNAME>GPS</WINDOWNAME> <DISPLAYNAME>App 1</DISPLAYNAME> <PAUSEMUSIC>GPS</PAUSEMUSIC> <LINECONTROL>NONE</LINECONTROL> <STARTFULLSCREEN>False</STARTFULLSCREEN> </APP1>
Reopen CENTRAFUSE and enjoy
But how about this:
I want to embeed MapMonkey Setup..
How to do this? The path for mapmonkey setup is something like this:
"c:\destinator apps\mapmonkey\mapmonkey.exe" /setup
and i dont know the window name..
Anyone??
EDIT: early in the morning, but will
work??
talking about netstumbler?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
I get this when trying to embed ZSNES
This is a tricky one
Any ideas?
MediaCars embedding had no problem doing ZSNES or Netstumbler
ZSNES runs in a full-screen mode which might cause problems. SNES9X might work better.
dscaler does the same![]()
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
this has happened with my GPS a few times too... try clicking media and going back it should refitOriginally Posted by aoLhaTer
hopefully tonight i'll get to post the adv. version. if you want a headstart... download http://www.autoitscript.com/autoit3/ and an editor http://www.autoitscript.com/autoit3/scite/downloads.phpOriginally Posted by Frankino
I will show you how to use this app to get around special situations like variable windownames (timestamp of netstumbler).
Cool, snes9x works just fine
The embedding is rather..."loose" though
The embed window doesnt stretch to its max, you can still see the window behind
