Results 1 to 6 of 6
Thread: How to fix library in 1.6?
    Banned Hwonder's Avatar
    Nov 2005
    NC
    What are the correct steps to removing and rebuilding a searchable library. I don't want to uninstall CF 1.6 and then reinstall to get the main setup. Is there an easier way? I am having a terrible time when I go to Media Manager and try to search for Artist, Albums, etc and nothing is there. I have to select Music Path to even see my MP3's. This is the first time this has happen and I can't figure it out. Thanks in advance for the replies.
    Oct 2004
    NY
    click on the tools button... in there you will find library rebuilding options...
    Aug 2005
    Where does the library copy songs to? does it do this as its way of categorising things? just wondering as now i'm out of hard disc space and have no idea where all the songs have been put and thought i'd ask before searching as i already have numerous copies of the same songs everywhere...
    VENDOR - Centrafuse veetid's Avatar
    Quote Originally Posted by zedevan
    You only have two options, rebuild and import... When you rebuild it simply deletes the music database and rebuilds it based on all your specified music paths...
    if you import it will display 2 dialogs... The first is asking for the source directory, you can select the drive letter to copy an entire USB stick or CD, then it asks for a destination folder, which is where it copies the files... Once it's completed copying it asks if you would like to auto add them to the music database...
    david
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    So that's what the import button does. Excellent! I was going to ask about that feature.
    Will CD Ripping be a feature in a later version? Would need CD TEXT or the ability to queue the ripped songs up for looking up on CDDB as soon as internet becomes available.
    Quote Originally Posted by Lum
    CD ripping is in the current version under tools labelled Import CD... It already looks up the CDDB information and in 1.7 I added the functionality for it to also grab the album art... You just need to make sure when you initially start ripping the CD you have an internet connection, otherwise it will display multiple dialogs asking you questions about what artist, album etc... and use this information instead...
    david
  1. Differences between 1.5 & 1.6, Tags
    By drstar in forum Centrafuse
    Last Post: 06-11-2006, 01:14 PM
  2. About to instal 1.6
    By thrmaln in forum Centrafuse
    Last Post: 03-16-2006, 05:35 PM
  3. Rebuild Library in 1.6
    By buurin in forum Centrafuse
    Last Post: 03-08-2006, 04:25 AM
  4. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 10:52 PM
  5. Palm Battery drain fix
    By Loftus in forum General Hardware Discussion
    Last Post: 05-01-2002, 09:57 AM
