Results 1 to 10 of 12
Thread: What kind of OBD box to use with CF
    Apr 2005
    France
    Hello,
    I would like to know what kind of OBD interface do you recommend to be the most compatible with CF ???
    Regards
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    You need one that is compatible with your car! NOT CF
    IIRC though, CF was made to work with the ELM scanner.
    MAKE SURE IT WILL WORK WITH YOU CAR THOUGH OR YOU'LL BE WASTING YOUR MONEY!!!
    Variable Bitrate bjm2020's Avatar
    May 2003
    Louisiana
    Get the obd2allinone unit. It works great with centrafuse and is compatible with all obdII protocols.
    EPIA 800, DWW-7VGA LCD w/Touchscreen, 256mb ram, dvd rom, ati radeon 7000 video card, 80 gb 3.5" hard drive.
    Aug 2004
    On the edge!
    But you STILL need to check that your car is OBDII because not all are Especially outside the US!
    My 1999 Nissan isn't!
    More info would help, car? year? etc
    May 2006
    Seattleish, WA
    Quote Originally Posted by bjm2020
    Ditto. http://obd2allinone.com/
    Quote Originally Posted by ShawJohn
    Ditto.
    Really? Bummer. Where was the car assembled?
    :: Mark
    Apr 2005
    i've tried two calbes. one is elm based, is working with other software than cf, but with less details. i've also tried a kl/kkl cable only for audi,vw,seat, works good with other software than cf, and absolutely not in cf. the reason is, that it's an absolutely different type of cable, which means, protocol is in software, not like the elm in hardware.
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    I have just received the USB model within 48 hours, +23 euros for customs ().
    But it seems not to work with my 98' 1.6l petrol peugeot!!!
    DOMMAGE!
    Aug 2005
    So basically if we have OBD1 we're screwed?
    May 2006
    Seattleish, WA
    Quote Originally Posted by L-U-R-C-H
    OBD I was never really a standard, so interfacing to it is a real headache. There are stand-alone readers out there, but they're very expensive. I've never seen a module for OBD I like we're talking about for OBD II.
    :: Mark
    Lum
    Lum is offline
    Variable Bitrate Lum's Avatar
    Jan 2005
    Liverpool, England
    The OP has a 2003 Hyundai Santa Fe, so I'm pretty sure it will have OBDII, most likely the ISO version.
    As far as I'm aware, the only officially supported OBDII cable is the ScanTool.com ELMscan range. Don't spend extra money on the expensive one they push on their front page that does all 3 variants of OBDII (unless you plan on changing your car regularly) get the ELMscan 3 in the correct variant for your car.
    Also I can confirm that the OpenPort cable from tactrix.com does NOT work with CentraFuse, so don't get that.
  1. Starting Fiberglass sub box!
    By pcmofo in forum Fabrication
    Last Post: 09-07-2009, 12:47 AM
  2. CF & Hibernation Issue
    By mmk999 in forum CF Bug Reports
    Last Post: 04-27-2006, 01:16 PM
  3. Loss of Configration
    By DaRacerz in forum CF Bug Reports
    Last Post: 03-15-2006, 09:49 PM
  4. XP Embedded to CF
    By Cheekz185 in forum WinNT Based
    Last Post: 05-04-2005, 03:01 AM
  5. cf newbie question
    By chrislloyd in forum Centrafuse
    Last Post: 03-24-2005, 06:01 PM
