does 4.2 have the alert functio on already?
www.superchargedmiata.net - all about roadster lifestyle
Impoting POIs via .dat in favorites folder is working. But i cant show the favorites on the map
btw: RC5
With Destinator6 Italy maps and Centarfuse RC5, import speedcamera don't work... *.csv
It seems there are some bugs in the .csv import. But you can convert the .csv into .dat and put them in the common/favorite folder. So they are imported as favorites but you cant set a voice sound or something right now![]()
Convert the TomTom files with poiedit in .dat and copy them into common/favorite folder. That works.
And yes, no audio und no viual alerts atm.
Another way to get warned from pois is, use freedrive in the background with imported speedcams and use the sound alerts. You only have to split your com port via xport.
But freedrive uses destinator 3 and not 6...
And if you install freedrive, the destinator plugin of centrafuse will not work right?
Or has that changed?
The FreeDrive maps are in c:/DestinatorApps/blabla with Destinator 3.
The Centrafuse maps are in c:/Flux Media/Centrafuse with Destinator 6.
So i think they are using different Maps with a different Destinator.exe and it will work. I cant test it atm because my car is in hibernation.
