Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
Thread: How do i add Speed Camera csv
  1. #31
    Variable Bitrate lazy_g's Avatar
    May 2005
    Netherlands (Bergen (NH))
    But destinator 3 and 6 do not install the program in the same directory?
    Because when i installed 3 a few months back, it overwrote 6 and the plugin did not start anymore...
    www.superchargedmiata.net - all about roadster lifestyle
  2. #32
    Sep 2006
    Thats maybe when you use Destinator standalone.
    Desti6 is integrated in CF Folder so both Destis should work parallel.
    Edit: You was right. CF and FreeDrive wont work parallel. Every programm needs different destinator system files, so only one programm can be used. I had installed CF and Desti6 map, checken Navi, worked. Then i installed FD and Desti3 map, worked. But the FD installation has overwriten some needed desti files from CF. So CFs navi is not working anymore
    We need a programm where we can save pois, which is scanning gps data and when we are on the position it makes an alert. Sounds easy but i found nothing like this
    Alternative should work a FreeDrive with desti6 support work to
  3. #33
    Feb 2007
    Question how do I apply a speed camera CSV file for mapmonkey?
    I have tried to figure out how I can apply a speed camera CSV file for mapmonkey? I cannot find any import or other CSV files in my mapmonkey or freedrive folders.
  4. #34
    Dec 2006
    Netherlands
    Quote Originally Posted by la6fja View Post
    i have the same trouble
    i also tried gatsohunter, but it won't eat any of the 4 csv formats provided by poi-edit. same goes for mapmonkey, it won't import any csv file from poi-edit.
  5. #35
    May 2005
    I still cannot import them!
    i tryed converting tomtom files to .dat and tryed freedrive .csv...
    It keeps on saying: "import failed, make sure the right map is loaded"
    I use destinator 6 maps for PDA (Version 2006.Q1.4155 - map of NAVTEQ)
    Or do i need different maps?
  6. #36
    VENDOR - Centrafuse veetid's Avatar
    you have to have the map loaded that the lat/long are in from the CSV...
    so if the CSV is full of lat/longs from say Munich, then you have to have the German map loaded or it can't verify and get the points to save them...
    you can go into planner mode to change maps and have it no auto switch back becuase of your GPS receiver...
    david
  7. #37
    May 2005
    well i have the Benelux map loaded and am importing the csv file for the benelux...
    also tryed the planner mode, keeps on saying the same...
  8. #38
    Registered User
    Feb 2006
    Berlin, Germany
    I have the same problem, too.
    I try poi´s from poihandler.com for germany and use a D3 german map and get the error message.
    Now I will try to build a file with only berlin poi´s and use the cf berlin map.
    I will give you the results later.
    Matthias
  9. #39
    May 2005
    rember centrafuse nav is made voor D6 and not D3...
    But what you said, i trued... tonight i am going to try to cut the maps, so i only have the netherlands, then see what happens...
  10. #40
    I doubt it will work with D3 maps...
    please post the file you are trying to import so I can see what is going on...
    just a piece of it should be fine, like 20 rows or something....
    david
  1. Structure of speed camera file
    By pijo1971 in forum Map Monkey
    Last Post: 10-27-2005, 03:39 AM
  2. Map Monkey v1.1.3 BETA 3
    By Ninja Monkey in forum Map Monkey
    Last Post: 03-29-2005, 09:50 AM
  3. Replies: 7
    Last Post: 02-26-2005, 01:46 PM
  4. Replies: 5
    Last Post: 02-23-2005, 06:36 PM
  5. Speed Camera problem
    By weekendowel in forum Map Monkey
    Last Post: 01-14-2005, 04:13 PM
