As title says how do i add speed camera csv file in cetrafuse. What is the add menu?
When i go to points of interest and hit the "+" button it sayd not possible?
Printable View
You hit the "+" in the favorites folder...
Create a favorites folder called Speed Cams, make sure the right map with lat/longs for the CSV you are importing is loaded... Then hit "+", browse to file, and let it run... It can take a while depending on how big the file is...
The problem is it's not 100% complete... The next release will add the ability to alert, which is the whole point...
someone might be able to tell where to edit the .dat file to turn the alert on... I'm waiting on Destinator...
david
again david thanks for this and thanks for the bug fix for the gps voice being able to go off now, some of my clients thought that might be an issue!
Any news on the uk beta testing?
ok tried this thismorning and got an invalid file format error? I thought it would import csv files into the fav menu?
The file has to be in the proper format... I used the same format that map monkey uses, the files you get from gpspassion.com... The first line is the headers, then the data starts with type, name, long, lat, etc... it's a certain format...
maybe in the future I will support other formats, but this was the only one I knew about at the time...
david
David can you point me in the direction of a csv file which would work so I can see how it is formatted. Thanks
You can google it and fine tons, but I think I meant to say the site:
http://www.pocketgpsworld.com/modules.php?name=Cameras
Here is an example of the format, it's the same other GPS softwares on mp3car used, you could search these forums as well and find tons of information and files...
davidCode:Type,Longitude,Latitude,Name,Speed
"MOBILE","-1.41791","52.32594","1","0"
"MOBILE","-1.04597","51.45426","10","0"
"MOBILE","-4.28974","51.8189","100","0"
"GATSO","-1.39172","53.25751","1000","0"
"GATSO","-1.38327","53.25888","1001","0"
"GATSO","-1.36801","53.26044","1002","0"
"GATSO","-1.35931","53.2644","1003","0"
Hi
I paid for the pocketgpsworld subscription and the csv file format is different to what you have above.
GATSO:1@40 Pocket GPS World (c) 2006 -2.17788 50.68304
GATSO:2@30 Pocket GPS World (c) 2006 -2.09934 50.70723
GATSO:3@20 Pocket GPS World (c) 2006 -2.08936 53.5027
GATSO:8@70 Pocket GPS World (c) 2006 -0.11078 52.02661
GATSO:10@50 Pocket GPS World (c) 2006 -0.39579 51.5215
