are you abte to create DSPs and xover networks, channel delay and so on? like kx does? ah btw David solved KX issues on CF RC5
I had installed the kX project drivers, but they dont work with CF. This thread has another solution with line-in from onboard sound, but i dont have onboard soundSo i searched for an alternative solution for using my audigy 2 zs with CF.
U only need the YouP-Pax drivers and the Audigy4.iso to patch your audigy 2zs to audigy 4. The advantages of audigy 4 is the better software, much settings and good tools.
On this page u have the instruction. Simply follow there instructions. Nearly all links there are down, here are some alternative links:
The Audigy4 image, the patch and the newest YouP-Pax drivers you can find here. The spkcal (Speaker Calibrator) is uploaded here.
Im happy with his solution, the sound is very good and every speaker can be controlled.
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
