Results 1 to 3 of 3
Thread: Cobb Accessport & Centrafuse
    Dec 2006
    Center of the Universe
    I have read everything there is to read and then some.
    Subaru Accessport cables are mentioned only in the OBD-2 section as solutions for data logging in conjunction with Tari Racing Software; and ECU Explorer and ECU Edit. This is something I have known and used successfully for 2 years.
    I would like to know if I would be able to use my Accessport cable with the OBD-2 feature in Centrafuse. I have set up the Com port to the same port that works in the DL1 data logger by Tari (Com 4) and I have tried both ELM devices. Now apparently I am either missing something (as in a real OBD scanner) or something is up. Can someone please explain to me what I am NOT doing right ? In the end I get a message stating connecting but nothing ever happens. So if I am unable to use it...what would you recommend instead ?
    Thank you.
    (2005 Subaru Legacy GT; Accessport; serial-to-usb; Centrafuse 4.x)
    VENDOR - Centrafuse
    raygun's Avatar
    Dec 2004
    Hotlanta (It's really not that hot)
    f1anatic-
    I looked into the Accessport devices, and while they do support the OBD-II, I can't find anything that says they use the ELM chip to do it. If this is the case, then no, we do not yet support that device. It's a similar device to the VAG-COM I believe, which has OBD-II but is implemented using a different processor. We currently only support the ELM chipsets. A good device we can recommend is the ElmScan 327, which supports all versions of OBD-II plus the new CANBUS protocol. It can be found here: www.scantool.net
    hth
    reagan
    Reagan
    Centrafuse
    http://www.centrafuse.com
    See our new Supported Devices List - http://www.centrafuse.com/hardware
    Dec 2006
    Thank you very much for the info.
    Sir, you have a private message. Or maybe an e-mail.
  1. New Release Centrafuse 1.20
    By veetid in forum Centrafuse
    Last Post: 10-10-2007, 07:12 PM
  2. No Sound in Centrafuse after Hibernate
    By barmy in forum CF Bug Reports
    Last Post: 07-26-2007, 11:45 AM
  3. Centrafuse New release & mappoint 2006
    By josgab in forum Centrafuse
    Last Post: 09-06-2006, 10:00 AM
  4. New Release, Centrafuse RC1 (1.7)
    Last Post: 08-02-2006, 12:14 PM
  5. Centrafuse SDK Information
    By veetid in forum CF SDK
    Last Post: 11-03-2005, 03:18 AM
