Page 4 of 4 FirstFirst 1234
Results 31 to 34 of 34
Thread: BluetoothControl - A Bluetooth Manager plug-in
  1. #31
    Apr 2007
    Is your server down? Cant DL the file???
  2. #32
    Phone Control Moderator zorro's Avatar
    Mar 2004
    Munich, Germany
    Not that I know.
    Skinning to go... VisualDesigner2!
  3. #33
    Nov 2008
    Hi, I've just registered to ask Zorro about this plugin. First of all, contacs plugin is said to run only in CF 2.0 (which uses bluesoleil drivers) but contacs plugin may use Bluetooth Control plugin (which works under Broadcomm ones).
    How do you manage to use Phoco and Bluetooth Control if the need diferent drivers?
  4. #34
    Mar 2004
    Munich, Germany
    Quote Originally Posted by fer_bicornio View Post
    The BluetoothControl plug-in is obsolte now because of 2.0. It was created for 1.4x. With CF 2.0 the Bluetooth stack has changed and the plug-in is pretty much useless now and therefore not longer supported.
    Though, this doesn't affect the Contacts plug-in at all. As soon as you copy vCards into the configured folder, Contacts will recognize it and add it to the contacts list.
  1. Cingular PDANet via bluetooth
    By DarquePervert in forum Wireless Communications
    Last Post: 06-23-2006, 04:22 PM
  2. Replies: 5
    Last Post: 05-28-2006, 04:52 AM
  3. Replies: 5
    Last Post: 07-12-2003, 01:43 AM
