Results 1 to 10 of 12
Thread: Navigon Navigator2 Plugin - Beta testers needed
    Newbie djerik's Avatar
    Oct 2005
    Denmark
    I have created a small plugin to integrate Navigon Navigator2 into CF.
    The sdk does not provide anything really usefull, and is therefore only in some degree used.
    If a new version shows up, or someone finds some of the information available through the SDK usefull I will implement that.
    But for now, please check that the window handling, navgation etc. is working.
    Installation guide.
    - Download & install the plugin as usual.
    - Modify "path" in NaviConfig.xml found in the plugin directory. This must point to the directory of NR2.
    - Modify NavigatoR.INI found in the installation directory of NavigatoR2. This should contain the following lines:
    [Dimension]
    Width = 653
    Height = 344
    Attached Files Attached Files
    System Developer
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    awesome...
    will try this out as soon as my carputer is up and running again
    Oct 2005
    Denmark
    * BUMP *
    It looks like the plugin has been downloaded 26 times, but still no comments?
    Does this mean that:
    - Nobody tried it out?
    - It doesnt work?
    - That it works perfectly?
    If anybody has any comment, please let me know.
    System Developer
    Sep 2006
    Ill try it in the next days, thanks :-)
    Feb 2008
    Hi,
    when i start the plugin it looks like this:
    My display is 8" 800x600
    Aug 2007
    Roma
    Great !!!!
    Oct 2005
    Denmark
    Quote Originally Posted by tentacle View Post
    Hi,
    I will look into it tonight. Can you send me a copy of you skin and settings?
    System Developer
    Oct 2005
    Denmark
    Quote Originally Posted by riko View Post
    Great !!!!
    Does this mean that it works great or?
    System Developer
    Sep 2006
    I tested it today. maybe you should delete the right side of your plugin, so its more space for the map. Im using the Onyx WS Skin in 800x600 so the plugin looks totally **** :/
    A plugin which just embed navigator in cf without this right side of yours would be perfect.
    Jul 2008
    Hi Djerik,
    would it be possible to compile your plugin for Centrafuse Version 2 or would you be so kind to provide the Source Code, so I can compile it by my self (of course for all others who are interested).
  1. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  2. slide show plugin for winamp 3 needed
    By babas151 in forum Software & Software Development
    Last Post: 02-01-2003, 12:24 PM
  3. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  4. winamp audio CD plugin needed
    Last Post: 05-14-2002, 04:47 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
