Results 1 to 4 of 4
Thread: Plugin for external Apps
    May 2007
    Brisbane, QLD, Aus
    Is the a Plugin for external Apps. I am a subaru owner and want to run evoscan inside of centrafuse, because i have a older subaru that doesnt support obd2 only ssmi.
    Is there one available at all and if there is where can i download it.
    May 2007
    Just add it as an external App. From the Settings click the plus sign (+) and click on Application. Name the app and pick the exe for the Evoscan app for the Application Location. If you want it to be inside the CF window (i.e. embedded) so you get the CF frame around it, just put in the Window Name.
    Once you are done, make a button for it by click+hold one of the buttons and it will prompt you to pick an application to replace. Pick the Evoscan app that you just made from the list and thats it. You have yourself a external app inside CF without any need for a plugin...
    Jan 2006
    Quote Originally Posted by nintwala View Post
    How do I figure out the window name for different programs I want to embed in CF?
    VENDOR - Centrafuse smeesseman's Avatar
    Mar 2007
    Detroit, MI
    Quote Originally Posted by popztarr View Post
    Usually it is the application name, minues the extension, but you can tell for sure by using a tool such as Winspector Spy.
  1. Replies: 119
    Last Post: 12-25-2007, 03:20 PM
  2. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  3. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
  4. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  5. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
