Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
Thread: Garmin mobile pc plugin request
  1. #21
    May 2007
    Can someone work on version for cf 1.47 I like the old version of cf better.
  2. #22
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    Quote Originally Posted by BIGGKATT01 View Post
    CF version 1.x is not anymore supported, now they are work on 2.0 version so updates are avalible only for 2.0...
  3. #23
    Constant Bitrate Putput's Avatar
    Sep 2005
    Belgium
    This might be your lucky day!
    I was planning on releasing a tool that would allow you to use Mobile PC under CF, so I'm gonna put it here. It might need some extra testing but I think it does what it's supposed to do. Here's how to use it:
    1. Unzip into a folder you like, no install required.
    2. Edit the ini file with Notepad like this:
    [GARMIN]
    Main Garmin Window=QUE_SUBAPP_WND_CLASS => leave this intact
    Sub Garmin Window=CDP_FIELD_WND => leave this intact
    Window top=60 => should be ok for CF running 800x600
    Window left=0 => should be ok for CF running 800x600
    Window height=535 => should be ok for CF running 800x600
    Window width=800 => should be ok for CF running 800x600
    Path=D:\Garmin\GarminMobilePC => path to Que.exe on your system, MUST BE ALTERED WHEN GMPC IS NOT INSTALLED ON D:\GARMIN\GARMINMOBILEPC !!!
    Start command=Que.exe => leave this intact
    Window search update=10 => change this to a higher value if CPU usage for cloak.exe is to high
    Remove welcome screen=1 => Removes the warning screen, change to 0 if you want to click the 'I Agree' button each time it starts.
    3. In CF install Cloak.exe as an external application with following info (or see screenshot):
    - Application name: as you like
    - Application location: browse to cloak.exe in unzip folder NOT QUE.EXE in Garmin folder!!!
    - Application parameters: empty
    - Window name: Garmin cloak app
    - Fullscreen button on!
    Thats it.
    What does it do?
    When you start cloak.exe after changing the ini file GMPC will be started in a window with width and height adjusted as in the ini file and you will see a small red button in the top left corner of GMPC. The warning screen automatically disappears (see ini file settings). When you click on that red button an onscreen, transparent keyboard appears that sends the typed keys to the Garmin window (make sure that you place the cursor in the edit box if it's not already there). When you click the 'enter' button or on the little red button again the keyboard disappears and you can continue working in GMPC. Also when you drag the Garmin window the red button will remain in the Garmin window's upper left corner, you'll see that it 'follows' the Garmin window.
    Just 1 small detail, as long as it's opened it will try to stay in the foreground, it will prevent other applications to come in front.
    Success!
    Attached Files Attached Files
  4. #24
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    is possible run it in 800X480 resolution?
  5. #25
    Sep 2005
    Belgium
    Quote Originally Posted by _Dejan_ View Post
    The minimum resolution for GMPC is 800x450, give it a try and share your findings. Change the window height to 450 in the ini file and see what happens.
    Putput
  6. #26
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    is you cloak app centrefuse dependent? Can it be used with other front ends? Just curious
    Live mp3Car Facebook Chat
  7. #27
    May 2007
    Just installed on my system cf 1.47 works great the only problem that i have is that the red circle doesn't apper on my screen i'm using the onyx skin. but other wise it works great.i can work around the osk issue its just great tht its finally embedded fantastic work putput can I change the position so i can have the music controls.
  8. #28
    May 2007
    Ok all Centrafuse, Garmin Mobile Pc users we should give a great thanks to putput for putting this plugin together so we can use this super nav sofware with centrafuse. It is by far the best nav software out there. ok so back to the plugin I have it working on my system with one bug i dont get the red circle on my screen to use the transparent osk but that is an easy fix. I also made the following changes so that I could have the bottom audio controls in Centrafuse. I made the following changes to the .ini file
    window top=48
    window left=0
    window height=470
    window width=800
    these changes made the bottom bar become visable and usable. once again i must give Putput big props for this plugin for us Garmin Mobile pc users.
  9. #29
    _Dejan_'s Avatar
    Jul 2007
    Slovenia
    window top=48
    window left=0
    window height=470
    window width=800
    just for info this is NOT plugin. This is external application which allow you to run Garmin Mobile PC embeded in CF, what you can do in CF too(External application - for me work)...
  10. #30
    May 2007
    Well if you havn't been following the centrafuse thread users of centrafuse have not been able to sucessfully embed garmin as a external app maybe with centrafuse 2.0 but not for ver. 1 hence this application that Putput has developed. For me upgrading to centrafuse 2.0 wasn't an option the load time was horrible for my system, took up alot of resources. ver. 1 works better for me thats why I and so many others needed this.
