I am no longer updating this thread. Please go to the active thread over at Centrafuse:
http://forums.fluxmedia.net/plugin-d...ce-plugin.html
Centrafuse iGuidance Plugin
Description: Plugin to embed iGuidance into Centrafuse
Latest version: 1.0
Requirements: Centrafuse 2.0
Supports: iGuidance v3 and v4 (2009 not tested yet)
Current Skins: Aura, Onyx Day/Night
Current Languages: English
Where to get it: iGuidance.zip
Issues:
(08/30/08)
Thanks to everyone for their feedback and support. Since I have not received any problems with the plugin, I updated the version to 1.0. Along with this new version, are two new features that were requested (see below for details). In order to update from a previous version, you'll need to replace iGuidance.dll as well as config.xml. If you've made custom changes to the config.xml and don't want to replace that file, then you can simply add this line of code before the end:
HTML Code:
<SHOWTOPBUTTONS>True</SHOWTOPBUTTONS>
(07/07/08)
I loved CFiG however as you probably know it doesn't work well with iGuidance v4 and is not built with the new SDK which makes it is a bit buggy. So, I took the liberty in creating my own version of it.
This plugin is completely flexible. To prevent the "dead button" issue CFiG had with iGuidance v4 when iNav changed the hotkey, I made all the buttons customizable. Meaning you can not only change the text of the button, but also the command it sends to the window. (Notice how the top buttons in the two skins are different) It currently only supports one button command (i.e. no alt, ctrl, etc) but that's something I hope to fix with a future release. Also, since nothing is hardcoded, this plugin could potentially embed any application. The ones I tested didn't work so well so I'm filing this feature as a potential future release, since all I cared about was to get Centrafuse working with iGuidance.
For all you iGuidance fans, please test this out and let me know what you think. This is the first release so I'm expecting a few bugs. Feedback is always welcomed.
Version 1.0: (08/30/08)- Fixed bug that did not reload iGuidance if accidentally closed
- Added support to remove the top buttons, from the setup menu, to maximize window size
Version 0.2: (07/07/08)- Updated the Setup to use the latest SDK which fixed the button text not being updated
