Results 11 to 20 of 28
Thread: Fusion Brain Plugin
  1. #11
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by Ineffigy View Post
    @SonicXtasy, could you email/send me your source code?
    I'm going to work with Proph's FB and create a Facade for FusionBrain. Then I'll work on making the Interface for CF. I've already written an application to query for the FB devices and read the data off of them but I don't have the FB in front of me to verify that everything works. Hopefully next week I'll have a facade ready for any other .NET developers to use.
    I'll be sending the source to proph later today in its current form. Excuse the mess!
    Live mp3Car Facebook Chat
  2. #12
    Apr 2006
    Dallas, Texas
    Ok, I got the code and looked at it. It looks like you bypassed the .NET assembly that comes with the Fusion Brain. Any particular reason why that was done?
    Software Developed:
    DS-ATX Controller Interface
    Laptop Shutdown Controller
    Considered Projects:
    TPMS Interface
    Bluetooth Handsfree Interface (WIDCOMM/BROADCOMM)
  3. #13
    Apr 2006
    Dallas, Texas
    Well, after digging into the history of UsbLibDotNet and then looking up FusionUSB.dll, it looks like UsbLibDotNet is a generic USB device assembly for .NET. Bad thing is, it requires the .INF file or a kernel service to report the devices. Looks like using the FusionUSB.dll will probably be the easiest to work with. I'll start with the facade tonight, as late as it is, I'll probably finish it up tomorrow. I'll see if I can get a FB as well so I can test all the inputs and outputs.
    Software Developed:
    TPMS Interface
  4. #14
    Apr 2006
    Dallas, Texas
    I didn't get home until midnight tonight so no progress on this tonight.
    Software Developed:
    TPMS Interface
  5. #15
    Mar 2006
    Colorado, but Canadian!
    FusionUSB.dll is a wrapper for Microsofts generic USB driver, written in C++
    LibUsbDotNet.dll is a wrapper for LibUSB generic USB driver, written in C#.
    Both cases you can bypass them and go straight to the source, but then you are on your own with the enumeration and correctly managing the handles. A real pain in a managed environment. If you are using C or something, then probably easiest to go for the source.
    And as a heads up, we are using the LibUSB drivers as a standard now, although not sure for howlong, so FusionUSB is outdated.
    Also a note is that FusionUSB is a simplistic wrapper with minimal error control. If you dont clear the handle on exit properly, it will never re-initialize the pointer until the program is restarted. That is the biggest reproduceable problem I have had with it so far, but like I said, it is phased out, so I have not edited the source to fix it.
    1.9in x 2.9in -- 47mm x 73mm
  6. #16
    Apr 2006
    Dallas, Texas
    Well, I started using the LibUSBDotNET driver at first but could not enumerate any USB devices until I installed a kernal service. I suppose there was an option to use an .INF file. Which are you using for LibUSBDotNET?
    Software Developed:
    TPMS Interface
  7. #17
    Mar 2006
    The Fusion Brain drivers which are based off of the LibUSB drivers enable the dll.
  8. #18
    Woodbridge, VA
    Blog Entries
    55
    two reasons..
    1. the plugins code that communicates with the FB was based on the first driver version.
    2. I'm teaching myself how to do this stuff and i'm taking the as long as it works approach.
  9. #19
    Apr 2006
    Dallas, Texas
    Thanks SonicXtacy02, I was just trying to determine the best way to write this thing.
    Software Developed:
    TPMS Interface
  10. #20
    Apr 2006
    Dallas, Texas
    Work has been hecktick lately, but I finally have some time this weekend to do some testing with the FusionBrain. Hopefully all will go well and I can say that the Facade is complete. Then on to creating the Centrafuse plugin.
    Software Developed:
    TPMS Interface
  1. RRFusion- My Fusion Brain plugin for RR
    By Sonicxtacy02 in forum RR Released Plugins
    Last Post: 01-25-2015, 03:48 PM
  2. *NEW* USB Input/Output Board -- Fusion Brain
    By 2k1Toaster in forum Fusion Brain
    Last Post: 02-22-2010, 03:33 AM
  3. How to add a Fusion Brain instance to your configuration file
    By 2k1Toaster in forum FB Documentation and Tutorials
    Last Post: 06-07-2008, 09:42 AM
  4. Noob has some biginner questions about the Fusion Brain
    By phreaknes in forum Fusion Brain
    Last Post: 04-29-2008, 03:57 AM
  5. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
