perilous, I was wondering, can you clarify a little bit how to customize your script to set the position/size of garmin mobilepc window (and keyboard) please? I'm trying to adapt it to run on my configuration but I'm not sure how to start, can you explait those top bottom top2 bottom2 values please? I'm thinking about using variables to set those coordinates, and get those variable using a defined ratio of the screen resolution in order to make the script work on every resolution
can you elaborate a little on your scripts? thanks a lot (and, good work I must say)
LinkBack URL
About LinkBacks
