Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 74
Thread: Integrate IGO or Garmin Mobile into Centrafuse
  1. #21
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    no problem check out my latest solution if you want, and let me know
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
  2. #22
    Sep 2007
    Quote Originally Posted by Frankino View Post
    "zwkb.exe quiet NoTapBox NoBumpBox largespacebar size=800x600x125% foreground=28 background=39 TypingTransparency=15"
    @Frankino
    where can I change these settings?
    thx
    I got it
    thank you, good work
  3. #23
    Jun 2007
    Help me chang layout keyboard
    Hi Frankino and guy...I can chang between language Eng and Thai by set change key sequence Cytl+Shift But I cannot change layout..Please suggest me.
    Can you modify PerilousOSK.au3 to run with ZWKB.BAT
    Thank you....
  4. #24
    Nov 2004
    Italy
    zwkb is english only, sorry
    I already pointed to you out what I think is the only solution in PM
    Quote: Originally Posted by anuchit
    Hi Frankino.Can I chang keyboard to other language? Please help me. ( Thai language )
    I think so, you have to
    -edit keyboardletters.gif to get the right graphic
    -edit keyboard.reg and change the letters
    -edit PerilousOSK.au3 and change the letter in the GetKeyPress() function, then compile the the modified script using autoit (backup the old one)
    it MIGHT work but I'm not sure
    good work
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  5. #25
    May 2007
    Tip
    I was having problems getting this working, but I figured it out. When you add the application in CF, do not enter the application title (Garmin Mobile PC) in CF. CF absorbs it if you do, and then Perilous' utility can't find it. Once I figured that out, it works perfectly!
  6. #26
    Aug 2005
    Error
    Hi Guys
    Great idea
    I have it working but when i try use the osk i get an error
    Error attached
    Any ideas for me to try
    Regards
    Jman
    Solved
    Stupid me i forgot the run keyboard.reg file
    again
  7. #27
    Nov 2004
    Italy
    glad you managed it
    enjoy this good piece of software
    Quote Originally Posted by Jman View Post
    Hi Guys
    Great idea
    Error attached
    Regards
    Jman
    Solved
    again
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  8. #28
    May 2008
    I've got an odd issue with my install. I had the same issue when I first installed on one of my car PC's, but then it seemed to go away and I wasn't sure why but it was working so I didn't bother to check further.
    Now I've attempted an install on my second car PC and I've got the same error but it won't go away....... any ideas ???
    When I try to start the Garminlauncher.exe application. When I enable debug it says waiting for app to initialize and then about 2 seconds later this comes up.
    I've checked the registry and the pathing is correct so not sure why this error is showing up. Any tips on how to diagnose would be helpful.
  9. #29
    Nov 2004
    Italy
    IIRC it happened to me too when I set up wrong positioning for the window in the .reg file
    Peugeot 206 1.4 HDi
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    M2-ATX
    8" Lilliput TS LCD
  10. #30
    May 2008
    Nah it's not working. Tried using all of the settings from here just to make sure and still the same error. I have run the application to try and get the application title, but it comes up blank as someone else mentioned, not sure if that's what's causing it.
  1. Centrafuse 2.0 RC3
    By smeesseman in forum Centrafuse
    Last Post: 05-21-2008, 10:29 PM
