the download is available on anotherthread:
http://www.mp3car.com/vbulletin/cf-p...entrafuse.html
However, i have tested this and if you have centrafuse 2.0, it is better to use use centrafuse to embed GMPC instead of this plugin.
i can't download it too.
Please reupload it ._.
is there something to decrease volume or pause music when it speaks?
OK Thanx for the heads up..
Do you have a step bij step on how to do this?
I actually wanted to embed iGO in to centrafuse 2.0
Do you know how this can be achieved?
I treid to download the Centrafuse IGO Help Apps Install but i still cant download it.
I get the same problem...
Could someone please upload it to rapidshare.com or megaupload.com please...
I really Need this piece of software in order to intergrate the Igo software in my centrafuse setup..
Thanx again for your time and patience.
With Kind regards,
Hind
I still can't download it too.
In that other thread there is the same link, so the result is the same, no downloading.
Someone must reupload it, there is no other solution![]()
For centrafuse 2.0 embedding application see this thread:
http://forums.fluxmedia.net/faq.php?...l&titlesonly=0
it works ... sort of
I can't get back to the main menu. i.e. i can change my music settings, but when i hit the back button it just shows the main menu behind iGO.
Any suggestions ?
edit: just realised it might be usefull to tell you guys what skin i'm using : VD2
'02 Toyota Celica TS
Carputer progress : [#######---]
Currently working on : software ...
Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
Parts needed: USB wifi dongle (with external antenna)
I have the exact problem like yours. I also tried to run iGOZoomer_109.exe directly from CF by adding it as application but I still got nothing. CF does not execute iGo (no iGo process in task manager). If I exit CF and run iGo from explorer, it runs, but in CF, it doesn't run.
== Updated ==
I just try and find out that if CF runs as shell, it won't launch iGo.
Hi everyone.I need to IGO CF HELPER APPS V203...I can't find it anywhere...Please help me..Thanks alot seeyou...
