Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 61
Thread: Garmin Plugin - Starting a cash fund for whom ever does it successfully
  1. #41
    Ogold007's Avatar
    May 2006
    Los Angeles
    Wow nicely done. Is the audio library specific to your CF plugin or can it be bundled with any frontend and/or plugin?
  2. #42
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    its indepandant...
    We will use it in CF2, CF3, RR, OM + we will make an option to control Windows Media, VLC, WinAmp
    So basically Lib interated applications will cover all posible CarPC cenarios
    [Esentually it is a microdiver that is injected into GMPC memory while it is runing so what ever GMPC sends to windows we have control over it, but unlike in hooking we can stop, modify, replace, monitor any comunication between windows and GMPC. Thats how we where able to optimize GMPC w/o modifying source codes. ]
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  3. #43
    Apr 2009
    Newark, New Jersey, United States
    this is coming along quite well : )
  4. #44
    Maximum Bitrate ws6vert's Avatar
    Sep 2008
    Baton Rouge
    Do any of these plugins utilize the functions in the queAPI.dll supplied with GMPC?
  5. #45
    Oct 2006
    i just hope you get your money, everyone seems to be benifitting
    i'll donate if i end up getting garmin.
    this might be the wrong place to ask, but is garmin better than the soo trusted iG?
  6. #46
    Jun 2007
    New York
    queapi has no use, well you can add routing point through it (if u make garmin think that you are an outlook)
    there is ocx however that with conjunction with custom "SDK" can be quite usefull. Unfortunatly that is requires 40% of GRMC to be rebuild from scratch in our own DLLs.
    Well that is my goal for Rebbelium V4 - in which we will keep original GMPC engine but everuthing else will be custom build... Cash Fund mark for that is at least +$600 to syartt development.
    Right now im focuded on releasing CF3 Native plugin - wwhich is schedulet to be out on Sat 06, but so far we gettng short on time
  7. #47
    Jun 2007
    New York
    to Punky: its like comparing Apples to Oranges, damn they both are fruits but they both work differently. Garmin is well thought of in interface but some time on some maps it goes nuts =) others go nuts on routing and terrible interface usibility
  8. #48
    Sep 2008
    Baton Rouge
    Quote Originally Posted by tempgp View Post
    queapi has no use
    I have been able to use DllImport of queAPI.dll to successfully implement the following exported functions:
    QueLaunchApp (launch GMPC or change GMPC to any screen)
    QueAPIOpen (Opens the API for function calls and callbacks)
    QueAPIClose (Closes the API)
    GPSGetMaxSatellites (Gets the maximum # of satellites supported by the software, 12 for GMPC)
    GPSSetMode (Can turn the GPS on or off)
    GPSGetPosition (Gets current GPS position ie. Lat, Lon, Elevation, etc.)
    GPSGetPVT (gets position, velocity, and time data in one structure)
    QueGetRouteInformation (Gets information about the current route ie. distance and time to next turn, distance and time to destination)
    And that's where I stopped due to my school requirements taking more preference. I have had no formal computer programming classes. Everything I know comes from google. So please someone tell me why you can not use the queAPI.dll supplied with GMPC?
  9. #49
    Jun 2007
    New York
    hmm let me take alook at it!
    can you extract the route turn by turn? and replace it w. something esle?
  10. #50
    Sep 2008
    Baton Rouge
    You can add waypoints... set a detour distance... and a point and route to it. Do a dumpbin on queAPI.dll and you will see all the functions exported from it. There are more functions exported than mentioned in the API documentation.
  1. Garmin mobile pc plugin request
    By BIGGKATT01 in forum CF Plugins
    Last Post: 08-01-2009, 08:06 AM
  2. Replies: 63
    Last Post: 03-10-2009, 08:49 PM
  3. pc reboot on sd startup
    By duanes7 in forum StreetDeck
    Last Post: 12-14-2007, 09:55 AM
  4. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  5. IRMAN plugin
    By knyarko in forum StreetDeck
    Last Post: 01-05-2007, 09:26 PM
