Results 1 to 3 of 3
Thread: CFTrafficcams 3.x.0 - Traffic flow cameras - Updated 5/2/14
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Press the button below to download from my forum
    or download it from the AutoAppMart - nb registration on my forum still required
    This is a beta test and if all goes well I will make 3.5+ version available in the CF Market.
    Donation(s) - Thank You
    SNOtwistR
    Current standalone version
    Centrafuse 2 Version
    Map of where cameras are (only the ones where I have GPS coords), your area not there? then get me the coords if the camera is already in the database or if cameras in your area not in database get me the camera urls and GPS coords.
    Clicking on the icon will give you the Camera ID and it's GPS coords. (trying to add location as well)
    Suitable for CF3.1 & CF3.5+
    Features
    • Shows local traffic flow cameras in your area
    • Three pages of up to 6 cameras per page
    • Use presets to display the cameras you pass most
    • Show the nearest 18 cameras by your GPS coords
    • A wide number of countries supported
    • Automatic download of latest databases for your country
    • PDF Manual for Installation and use
    Updated to 3.5.5 (for CF3.5+ / CF 4.x)
    3.5.5
    Added
    Plugin to PluginCommand
    "getcamera",<cameraID>,<path to save image>
    Changed
    Camera pages now loop round - Request JohnJore
    When changing from GPS to presets old images are erased - Request JohnJore
    When camera not set text displayed to indicate this
    Fixed
    Camera display in search screen showing wrong camera image from up/down buttons. Reported JohnJore
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Q. Why should I use this plugin version in CF as opposed to the Standalone version?
    A. There is no reason why you shouldn't use the standalone version, however this version has better integration with Centrafuse
    Q. Why is my country not supported?
    A. I have collected as many countries as I can where I can, either from searching or other users providing links, if you country is not supported it is either I haven't found a website with the cameras or if I have they are moving images which TC does not support at this time. Bear in mind if the site is not in English I may have trouble understanding it.
    Q. Why is my State/Town/City not supported?
    A. I have collected as many countries as I can where I can, either from searching or other users providing links, if your state/town/city is not supported it is either I haven't found a website with the cameras or if I have they are moving images which TC does not support at this time.
    Q. I have found a site for my Country/State/Town/City what do I need to do to get these added to the databases?
    A. If it is a new Country then firstly provide me with a link, if it is not in English you may have to harvest the info yourself. Please provide the info in the following format
    <url of camera>
    <Location of camera including town/state>
    <lat>
    <lon>
    NB the lat and lon need to be in decimal format and not Degrees Minutes, seconds. ie (34.4567,-23,9465)
    Q. How can I download this wonderful creation?
    A. Register on my forum at www.en4cer.co.uk/forum , when activated go to the downloads section. Or you can download from the AutAppMart, bear in mind you will still need to register an account on my forum to be able to register it.
    Q. I have registered on your site but am still not activated, why?
    A. I do not monitor the forum registrations 24/7 so it could take hours or possibly a day or two before I can activate you. If I am going away I will normally put this info into the news section of the forum. If however after a few days of registering you have not been activated then contact me via PM here. Using the same username as you do on here will help you get activated quicker.
    Q. Does this application only work with CentraFuse?
    A. Yes, this is a dedicated CentraFuse Plugin, However there is a standalone version available.
    Q. How do I change the size?
    A. The plugin will run at the same size as CentraFuse.
    Q. Would someone care to send me this?
    A. They can, but bear in mind you still need to register an account on my forum.
    Q. Does this show redlight and speed cameras?
    A. No, this is only for traffic movement cameras, for speed cameras a red light cameras try Gatso Hunter.
    Q. Is the video live or updated? or mix?
    A. Currently this is only static image cameras, these get updated by the websites anything from every second to some which update every 20mins.
    Q. Does your plugin accepts video traffic cams?
    A. Not at present, this maybe something for the future, but at the moment this would probably take too much bandwith.
    Q. I would love to be able to add some custom images to the traffic cam app?
    A. At present this is not possible, but it is something I will look into
    Q. How do you pull coordinates for traffic cams?
    A. This can be very laborious.
    One method is to use google earth combined with the website the cameras are on and the Traffic Camera pictures.
    You will need to look at roughtly where they say it is (there is normally a map of sorts), look at the picture, zoom in on google earth until you can marry the picture image with what is seen in google earth and then read the co-ordinates. It also helps if you are fairly familiar with the area/country.
    Sometimes you are lucky and if you look at the source of the page with the map, it will sometimes provide the GPS coords in their somewhere, these can then just be copy and pasted into notepad.
    Q. Why do you need the GPS coords with the cameras?
    A. Two fold, one is to be able to see on a map where a camera is in the serach screen, help you decide if it is somewhere you go. And secondly to be able to use those cameras with the BYGPS function
    Q. I keep getting this error; error x or this function doesn't work?
    A. First, check the whole of this thread to see if the same questions has been asked before and more importantly answered before. Second go to the settings screen and set Debug to true, do what you do to get the error then run the 11ADebugCollector found in the CFTrafficcams plugin folder and then send me the debug folder it creates (Should zip it up). Address to send is in the PDF Manual or use the email at the bottom of my site.
    Q. I've changed the Database name in the Countries screen but I don't get a database for the country selected
    A. Check that your firewall has not blocked www.dropbox.com or www.en4cer.co.uk as this is where the DB's are stored.
    Q. What is the current database version for my country? (Cameras with coords / total cameras)
    A.
    Code:
                                     (Coords / Cameras)           Percentage of cameras with coords
    UK Database version=UK007          (1284 / 1612)                       79%
    US Database version=US015          (1477 / 4396)                       33%
    Austria Database Version=AT001        (0 / 65 )                         0%
    Australia Database Version=AU004      (279/ 281)                       99%
    Belgium Database Version=BE001        (0 / 40)                          0%
    Brazil Database Version=BR002        (71 / 147)                        48%
    Canada Database Version=CA004        (38 / 414)                         9%
    Czech Rep Database Version=CZ001      (0 / 74)                          0%
    Germany Database Version=DE003       (14 / 62)                         22%
    Denmark Database Version=DK003      (119 / 135)                        88%
    Estonia Database Version=EE001        (0 / 28)                          0%
    Spain Database Version=ES006         (60 / 326)                        18%
    Finland Database Version=FI003      (249 / 544)                        45%
    France Database Version=FR003        (91 / 105)                        86%
    Croatia Database Version=HR003       (71 / 72)                         98%
    Hungary Database Version=HU003       (59 / 81)                         73%
    Ireland Database Version=IE003       (21 / 91)                         23%
    Iceland Database Version=IS001        (0 / 58)                          0%
    India Database Version=IN001          (5 / 80)                          6%
    Italy Database Version=IT001          (0 / 29)                          0%
    Luxemburg Database Version=LU002      (0 / 104)                         0%
    Malaysia Database Version=MY002       (0 / 38)                          0%
    Nederlands Database Version=NL001     (0 / 31)                          0%
    New Zealand Database Version=NZ001    (0 / 48)                          0%
    Norway Database Version=NO001        (40 / 43)                         93%
    Poland Database Version=PL002        (32 / 425)                         7%
    Portugal Database Version=PT002      (16 / 182)                         8%
    Russia Database Version=RU001         (0 / 33)                          0%
    Singapore Database Version=SG003     (46 / 46)                        100%
    Slovenia Database Version=SI002       (0 / 199)                         0%
    South Korea Database Version=KR001    (0 / 27)                          0%
    Sweden Database Version=SE002       (207 / 244)                        84%
    Venezuela Database Version=VE001      (0 / 30)                          0%
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    3.5.5
    Added
    Changed
    Fixed
    Also the Australian DB has been updated and all cameras now have GPS coords
  1. RRTrafficcams 2.0 - Traffic flow cameras - Updated 17/11/11
    By Enforcer in forum RR Released Plugins
    Last Post: 02-01-2016, 06:12 AM
  2. CFTrafficcams 2 - Status - Beta Release 16/03/2009
    By Enforcer in forum CF Plugins
    Last Post: 09-22-2011, 12:15 AM
  3. RRTrafficCam - Traffic flow cameras - Status : Released
    By Enforcer in forum RR Plugins No Longer Supported
    Last Post: 12-14-2010, 08:59 PM
  4. Updates to CFTrafficCams
    By Enforcer in forum Auto App Mart
    Last Post: 11-27-2010, 11:48 PM
  5. Upfront sideview cameras for traffic situations?
    By durwood in forum General Hardware Discussion
    Last Post: 11-20-2006, 02:18 PM
