Results 1 to 10 of 17
Thread: StopWatch CF plugin: lamo C# plugin with source :)
    FLAC alti's Avatar
    NY
    UPDATE: New version available!! Release : StopWatch Plugin for Centafuse
    First plugin working!
    It does nearly nothing, but may one day be remotely usefull and was a great learning experience with the centrafuse SDK
    Anyone have any ideas to make it better? right now it just stops(resets) and starts a timer.
    for now a screenshot :
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
    Variable Bitrate StrataG's Avatar
    Aug 2005
    New York
    Probably would be a good idea to have at least 2 timers available. Maybe the second timer could be started and stopped with the computer. Also saving timed results with options to name them. Could be useful for people who drive a lot for business.
    FLAC alti's Avatar
    NY
    There are two folders in the zip, the one called 'stopwatch' contains the plugin, just unzip it to the /plugins directory of centrafuse, assign it to a button and you are ready to go. I did not make a setup dialog for it yet, but i wil soon. The other folder in the zip, 'StopWatchPlugin' contains the source.
    If anyone wants to add, modify, remake ect. go for it.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    The link seems to be broken
    FLAC alti's Avatar
    NY
    Quote Originally Posted by donde
    I just fixed it
    should work now
    I put a second timer in and made it so it pauses when you toggle the start/stop for each timer. The lower two buttons reset the timers, I did not yet get to creating a xml of saved times but will get to it eventually, or if someone else wants to take a shot at just email me the completed code and i will post it, enjoy!
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Huge props for even getting something working
    You are a far greater man than I
    FLAC alti's Avatar
    NY
    Quote Originally Posted by aoLhaTer
    Thanks, its nothing special, just wanted to throw it out there for others as a lightweight SDK example.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    FLAC alti's Avatar
    NY
    I just updated it with working reset buttons, updating the screen shot above
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    FLAC alti's Avatar
    NY
    Just finished mid-terms
    so i got the setup done, now it is skinable and you can change the langauge file ect.
    I am going to add an xml save feature for the times.
    My Install
    Software:
    CFiG v1
    CarShell
    StopWatch
    Raw Wave justintime's Avatar
    Apr 2005
    Thanks alti. This is a good small example for others to get braver.
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  1. USB HU adapters plugin source and installation
    By jbors in forum Software & Software Development
    Last Post: 06-28-2005, 01:35 PM
  2. GPS:MM shutdown RR when switch skin
    By MatrixPC in forum RR Bug Tracker
    Last Post: 05-12-2005, 12:07 PM
  3. master volume doesnīt work
    By free2world8000 in forum RR Bug Tracker
    Last Post: 02-17-2005, 01:08 PM
  4. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  5. Keypad plugin source code
    By brandondere in forum General MP3Car Discussion
    Last Post: 12-28-2000, 10:10 PM
