Results 11 to 20 of 30
Thread: Freecom DVB-T USB2 stick
  1. #11
  2. #12
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    No
    Not tried the above either, CarPC has been left for the time being...
    I need to do a clean install and sort some HW/driver issues out, then get back to playing with it properly
  3. #13
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Quote Originally Posted by ShawJohn
    No
    Will you keep us informed???
  4. #14
    Nov 2006
    Sorry..Iīve my dvb freecom working with winamp tv pluging and now... I want push a button in the RR (for example label TV : )) for this work...Itīs possible? thanks in advance..
  5. #15
    Oct 2004
    just curious how well does this thing work on picking up digital tv stations, does it pick up the HDTV over the air too?? and where abouts do u live anywayz. cause i heard from somebody that thos things dont work in the USA
  6. #16
    Oct 2006
    Banderas2000, did you allready managed to get the stick fully integrated in RR?
  7. #17
    Aug 2004
    On the edge!
    IIRC DVB-t is European ONLY!
    And DVB-t will NOT work if the aerial is moving, it has to be stationary to pick anything up
    It also seems to need plenty of CPU grunt too as when I run TV on its own its fine, but with other programs running it gets jumpy
  8. #18
    Nov 2004
    FRANCE
    Quote Originally Posted by ShawJohn View Post
    You can with DUAL TUNER (I have one. Works over 150 km/h) but it is not PC. I can't find the same thing (DUAL tuner) for PC...
  9. #19
    Aug 2005
    N Wales
    Quote Originally Posted by coucouillu View Post
    What differences does it being a dual tuner make? Is it dual as in two dvb-t tuners or dual as in one analogue and one dvb-t? If one is analogue then that obviously isn't dvb-t working whilst moving. If it is 2 dvb-t tuners then I still don't see the relevance of how it being dual makes it work whilst moving. The fact its dual just means you can watch one program and record a different one, or record two different ones.
    You can get dual tuners for PC. Most usb ones are dual as in one analogue and one dvb-t. There are some true dual dvb-t tuners, they are mostly PCI (or the terratec cinergy one is PCI-express). I have used the Win TV NOVA T-500 in a media PC but not car PC. Works well, have no idea about on the move, but I suspect it wouldn't. It's just 2 of the same tuner that a single card has. So if your's does actually record using dvb-t on the move then it's not because of the fact it's dual, must be some other reason, good tuner or signal maybe.. ?
    Hardware: MII12000/512MB RAM/250GB HDD/8" touchscreen/slot load dvd/M1-ATX, 802.11g/bluetooth
    Software: Road Runner, Map Monkey
    Working on: reliablility!
  10. #20
    Newbie liquefact's Avatar
    Jun 2006
    Istanbul, Turkey
    Terratec has a dual tuner usb device. Name was Cynergy Diversity or something.
  1. USB2 device on USB1.1 Hub...
    By MC_Stoo in forum Power Supplies
    Last Post: 11-05-2005, 06:30 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. 5" USB2 CONNECTED!!! LCD with touchscreen and 450cd/m2
    By Scouse Monkey in forum LCD/Display
    Last Post: 04-13-2005, 05:56 PM
  4. USB2 or FireWire?
    By SoFlaLude in forum General Hardware Discussion
    Last Post: 03-11-2004, 06:56 PM
  5. Booting with USB memory stick
    By Fluffy in forum General MP3Car Discussion
    Last Post: 10-01-2003, 06:47 PM
