Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Freecom DVB-T USB2 stick
  1. #21
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Quote Originally Posted by liquefact View Post
    Terratec has a dual tuner usb device. Name was Cynergy Diversity or something.
    i just found this one too :
    http://www.cartft.com/catalog/il/70
    DAVID, do you think these hardwares will soon work with CF?
  2. #22
    Nov 2004
    FRANCE
    Quote Originally Posted by RichEO View Post
    What differences does it being a dual tuner make? Is it dual as in two dvb-t tuners or dual as in one analogue and one dvb-t? If one is analogue then that obviously isn't dvb-t working whilst moving. If it is 2 dvb-t tuners then I still don't see the relevance of how it being dual makes it work whilst moving. The fact its dual just means you can watch one program and record a different one, or record two different ones.
    You can get dual tuners for PC. Most usb ones are dual as in one analogue and one dvb-t. There are some true dual dvb-t tuners, they are mostly PCI (or the terratec cinergy one is PCI-express). I have used the Win TV NOVA T-500 in a media PC but not car PC. Works well, have no idea about on the move, but I suspect it wouldn't. It's just 2 of the same tuner that a single card has. So if your's does actually record using dvb-t on the move then it's not because of the fact it's dual, must be some other reason, good tuner or signal maybe.. ?
    I meant DUAL DVBT TUNER and not one analogue and one DVBT.
    It seems you don't have understood why DUAL DVBT TUNER.
    This is because when you drive, you will lost reception of signal. With the second tuner, you will recept another signal and the brain of the card will compare the two signal and will mix them in one output, more stable, uncutted.
  3. #23
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    DVB-t CANNOT be picked up on the move!!! No matter how many tuners, or what aerial
    Only analogue!!!!
    As Coucouillu says, the one that works on the move or when digi signal is weak is analogue
  4. #24
    Newbie liquefact's Avatar
    Jun 2006
    Istanbul, Turkey
    Quote Originally Posted by ShawJohn View Post
    Only analogue!!!!
    And what do you think about this document says? Is it wrong what they say?
    infoCAR www.infocar.com.tr
    Fiat Coupe 20V
    SP13000/512MB/80GB, Lilliput 7'', Holux GR-236
  5. #25
    Mar 2005
    Wiesbaden/Germany
    sorry guys... I have kept too much information for myself...
    I put the magnetic antennas of the TerraTec Diversity on the roof of my car and started a short testride around the corner (only on interstate <100km/h) - certainly It works as I expected: beautiful.
    The TerraTec driver itself is a BDA driver so CF needs quick BDA support. If someone can send some code to David he might be somewhat happy...
  6. #26
    Aug 2004
    On the edge!
    What document
    If I am proven wrong fair enough But from the research I did, the motion thing is a limitation with the DVB-t protocol which means the aerial MUST be static to receive a useable signal.
    You shouldn't be watching TV on the move anyway
  7. #27
    Jun 2006
    Istanbul, Turkey
    What document
    I'm sorry, forgot to give a link
    http://tven.terratec.net/modules.php...rticle&sid=251
    Here is what it says:
    "Likewise, using the Diversity function in DVB-T service areas allows for interruption-free reception while traveling - ideal for long train rides or for entertaining children in the back seat of your car."
    I didn't test though.
    Fiat Coupe 20V
  8. #28
    Aug 2004
    On the edge!
    Hmmm. So it should work!
    All I know is that on mine if I even so much as slide the aerial across my window sill the signal dissappears. Someone else on here told me that was a physical limitation of the DVB-t Protocol and thats why the likes of BMW don't use DVB-t for their incar TV i-drive module...
    Maybe the info is wrong!
  9. #29
    Nov 2004
    FRANCE
    SURELY.
    Only DUAL DVB-t tuner could work on the move.
  10. #30
    Feb 2007
    Has there been any update on this? I was just about to order one of these Freecom tuners from the web when I thought I should check compatability.
    Have you managed to get yours wokring witin CF yet John? Did you try the suggestion put forward by Rmack?
    Adam
  1. USB2 device on USB1.1 Hub...
    By MC_Stoo in forum Power Supplies
    Last Post: 11-05-2005, 06:30 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. 5" USB2 CONNECTED!!! LCD with touchscreen and 450cd/m2
    By Scouse Monkey in forum LCD/Display
    Last Post: 04-13-2005, 05:56 PM
  4. USB2 or FireWire?
    By SoFlaLude in forum General Hardware Discussion
    Last Post: 03-11-2004, 06:56 PM
  5. Booting with USB memory stick
    By Fluffy in forum General MP3Car Discussion
    Last Post: 10-01-2003, 06:47 PM
