Results 1 to 7 of 7
Thread: OBDII plugin (KL/KKL) ?
    Apr 2005
    Hi all VW, Audi, Seat or Skoda drivers. I hope there are some out there, maybe more in europe, i think. what do you think about an OBDII plugin, which uses the KL/KKL pins and the specific protocoll like the good VAG-COM to work with centrafuse. it could be very inderesting for users of any of the cars above, because much more details could be read out of the car, instead of using an ELM based product. and the KL cables is much cheaper too. but the implementation i think is harder, because the cable is a stupid one, all the information to get something out of the car is made in the software, not like the ELM system, mostly done by the cable. mybe we can use the vag com demo version as base software to get the parameters of the needed values like speed, fuel and so on? any ideas?
    Mar 2004
    Vancouver, BC, Canada
    Source Code to Ross-Tech VAG-Scope
    http://www.ross-tech.com/vag-scope/downloads.html
    Should give you an idea of how to get the values you want.
    Apr 2005
    wow, i didn't know that the source code is free for this app, this could help a much. thank you man !!
    Mar 2004
    Thats the source code for VAG-Scope, not VAG-COM. Should help regardless.
    Apr 2005
    if there is the communication and some examples inside, it helps.
    _
    Mar 2004
    Little Elm, Texas
    anything ever come of this?
    Jan Bennett
    Apr 2005
    Sweden
    Anyone working on this?
    Whats the best OBD 2 cable for my VW Golf -99?
  1. OBDII Signal Splitter (for Infiniti G35)
    By Caelric in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 04-14-2007, 09:32 PM
  2. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  3. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
  5. Resumer Winamp plugin..works with MPC, too
    By Tony S in forum Software & Software Development
    Last Post: 03-30-2002, 06:10 PM
