Results 11 to 20 of 26
Thread: CF1.6 MapPoint 2K4 Plugin Alpha Source Code Now Available
  1. #11
    May 2006
    Seattleish, WA
    Quote Originally Posted by daemon
    Yall,
    The plugin works great as well with MP2K6 without any problem. Great Job.
    Now THAT is some awesome news!
    Time to install!
    :: Mark
  2. #12
    Slovenia (EU)
    Quote Originally Posted by P3rv3rt B3ar
    I certainly hope u happen to be the 2nd female member of these forums...
  3. #13
    Raw Wave justintime's Avatar
    Apr 2005
    Good work at putting this together, and making it available to everyone. With little fanfare to boot. Kudos!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
  4. #14
    May 2006
    Seattleish, WA
    Yall,
    fwiw, as of this morning, I can confirm this! It is SO cool to have full maps in CF!
    THANK YOU PAUL!
    :: Mark
  5. #15
    Sep 2006
    new centrafuse not work with mappoint 2006
    Hi i'm installed cf plugin but not work with the last release of centrafuse i have mappoint 2006.
    any solution pleaseee
  6. #16
    May 2006
    Seattleish, WA
    Quote Originally Posted by josgab View Post
    "but not work" is pretty vague... What are the specific symptoms?
    Are you having issues getting a button configured to launch it? Does the plugin load Mappoint but the GPS doesn't lock? Do you get a message saying that it can't find maps?
    Which version of CF is this?
    :: Mark
  7. #17
    Apr 2006
    Will CFmapoint2006 work with RC2?
  8. #18
    May 2006
    Seattleish, WA
    Quote Originally Posted by black06stang View Post
    Yes, that's the setup that I'm running in my truck.
    Did you try Paul's 0.82 that he released on 9/1?
    :: Mark
  9. #19
    May 2006
    Seattleish, WA
    Hi;
    I just replied to your question on the CFMapPoint dev space. You gave more information over there, (that you only have NY and Berlin maps), so I'm thinking that you're actually running Destinator under CF and not Mappoint. the CFMappoint plugin doesn't _replace_ Destinator (the stock nav system in CF), it installs along side of it.
    To use CFMapPoint, you have to create a button in CF to launch the plugin. Have you done that, or are you still clicking the "NAV" button and thinking that will launch MapPoint?
    :: Mark
  10. #20
    May 2006
    Seattleish, WA
    {paraphrased from my post on Paul's dev site}
    You need to create a button for CFMapPoint. To do this:
    • In CF, go to SETTINGS, page DOWN one and you should see BUTTON LAYOUT. Select it, then hit SETUP.
    • This is where you configure the buttons that appear all over CF. The first set are the buttons that appear in the MENU drop list, then come the first page, then the 2nd, then the 3rd. Pick an empty spot, then click SET.
    • Scroll through that list until you see "CFMAPPOINT". Select it, and click OK.
    • Click CLOSE, then CLOSE again.
    • Flip through the pages until you find the button labeled "CFMAPPOINT".
    • Click it.
    :: Mark
  1. Need spectrum analyzer source code
    By XPLORE in forum Software & Software Development
    Last Post: 12-07-2001, 11:19 AM
  2. MPXPlays Source code is available!!
    By Fosgate in forum Software & Software Development
    Last Post: 05-30-2001, 06:18 PM
  3. c++ LCD source code
    By mprover in forum Software & Software Development
    Last Post: 01-19-2001, 04:32 PM
  4. Keypad plugin source code
    By brandondere in forum General MP3Car Discussion
    Last Post: 12-28-2000, 10:10 PM
  5. Dos MP3 player/decoder source code?
    Last Post: 03-23-2000, 04:46 AM
