BTW thanks for integrating Mappoint into CF, to me this is one of the most exciting software developments for CF. Since I already had Mappoint 2004 lying around the house, this will be perfect!
If I open Mappoint...not in CF I can obtain a lock. But when I use the plugin, the lock button does not work.
Have you config'd the GPS COM Port in the plugin's settings?Originally Posted by black06stang
Have only ever run w/ one type of GPS receiver, so I have not tested that this works w/ all GPS receivers.
(I have a new one coming in the mail in the next few days)
What GPS receiver are you using?
Pv
- CentraFuse MapPoint Plugin (works w/ 2004 and 2006, USA and Europe)
http://workspaces.gotdotnet.com/CFMapPoint- 2003 Nissan 350Z with CarPC and TV
http://www.swooby.com/z/navpc/
Just the standard one that came with microsoft streets and trips. I have to check the settings on the plugin section...
Nope, it still wont lock on. I have it set on com4 and the microsoft gps unit is plugged into com4. Any suggestions?
Ditto over here here... Didn't you mention in another thread that you broke the GPS code at .7.03?Originally Posted by black06stang
And there's also an issue with you not showing virtual com ports - like those that come from Xport.
My full MapPoint install works fine with my GPS receiver on either the virtual or physical COM ports. CFMapPoint 7.03+ doesn't.
:: Mark
fyi... GPSInfo works perfect on my system. both with physical and virtual COM ports. I'm sitting in the car now watching it watching the GPS lock into sats.![]()
:: Mark
Is this problem going to be solved or am I just wasting my time?
This is ****in me off! Why wont it lock onto my gps location? Now a message pops up saying "query....". Will someone please help me? I have already reinstalled it.
It looks like Paul released a debug version (0.7.05) overnight. Have you tried it?Originally Posted by black06stang
I'll be loading it this morning...
:: Mark
