No news ?
Hello David,
I'm using a WINTV USB Hauppauge in CF with Radiator. Is there any way to route the sounds thru USB like DSCALER make.
We can save 1 audio cable and not using a poor quality of line in sound card (from my laptop for example) and certainly could be more easy to setup volume and other stuff.
Regards
AIR-V
No news ?
You are using a Hauppauge usb FM tuner? Which one?
Opus case. MB 899 core duo 2.0ghz
Dual vga out, 400 gb hard drive, Centrefuse front end
zapco 1000.4 for zapco 6.5 componets
zapco 1100.1 for 2 13" W6.
I' m using the WINTV USB FM. It make everything but not really well.Originally Posted by inniss777
The sound output is not really good and generate a buzz sound. That's why i'm thinking it could be good to use the sounds thru USB like DSCALER make (TV or FM mode).
Regards
RV
The Radio has been redone... It uses a RadioModule plugin system and all the source code for the Radiator/DLink/RadioXtreme will be included in the next SDK...
It is a simple interface that just has a handful of functions. People will be able to easily add custom support for radios, like the HQCT which I plan to work on next, unless someone beats me...
I got it finished last night, so it will be in the next release for sure...
david
