Page 1 of 6 123456 LastLast
Results 1 to 10 of 53
Thread: APOI Plugin: Netstumbler container + POI generator
    May 2006
    Belgium
    Hello,
    So here's my second plugin (i really enjoy creating them).
    The initial idea was to create a non-gui plugin that runs NetStumbler in the background and generate POI's for TomTom i use with my other plugin (PPCEmulator). So practicly it will search for AP's (Access Points) and generate POI's based on the location of the AP for TomTom, so i can easely navigate to a AP i've passed.
    Now as i was coding i thought it maybe would be nice to see a list of the AP's found (generally the information NetStumbler shows). To that's when i decided to make a GUI and dump the netstumbler window in it.
    Features:
    - Search WiFi Access Points and save there location using GPS data (uses netstumbler)
    - View and control NetStumbler within CF.
    - Convert the netstumbler data to 75 different filetypes every 10 minutes (uses gpsbabel).
    Bugs:
    There's 1 bug that i'm aware of. Thats the Run On Startup option. For some reason NetStumbler shuts down when u try to launch it when CF is starting.
    For now i don't know how to fix it, but i do know it has something to do with the SetParent function and the fact that de new parent is not visible. Netstumbler somehow dousn't accept that.
    So don't use the Run On Startup option for now.
    Requirements:
    - NetStumbler 0.4.0
    Download:
    http://users.pandora.be/_freakz/apoi_plugin/APOI.zip
    Tips:
    If you want to generate poi's it's best you create an empty textfile with the correct name and extention and then browse to it in the plugin setup page.
    Screenshots:
    May 2006
    Belgium
    UPDATE:
    - Run On Startup option fixed , its a bit of a workaround. It just sets the plugin visible before calling the SetParent and then make it invisible again. Only thing is you get a short flicker when CF loads.
    - Added Update Interval option allowing users to set there own update interval.
    Download:
    btw, 15 views and no commets?
    If you think it sux-*** feel free to tell so
    Para Laura thanatos106's Avatar
    Nov 2004
    Miami Beach,FL U.S.A
    Good job... I like the way the Icons are set up. colors too.
    Thanatos.
    RexBruMet Skin for FrodoPlayer
    Nissan Aux-in MOD
    Quote Originally Posted by bgoodman
    We're an international forum, post in whatever langauge you like.
    FLAC coucouillu's Avatar
    Nov 2004
    FRANCE
    Hi,
    looks good. Have to try it in car.
    That is what I was looking for...
    Quote Originally Posted by CoolCow
    - Convert the netstumbler data to 69 different filetypes every 10 minutes (uses gpsbabel).
    Perhaps I missed something...69 different filetypes..What about Destinator version in CF???
    Does this software could be used to feed POI in CF GPS plugin?
    Tips:
    What is the name and the extension?
    The software can't select an output file.
    Raw Wave justintime's Avatar
    Apr 2005
    Wow, Need to try this!! Thanks for sharing!
    2002 Honda CR-V
    Spent so far: $1105.90
    ...or even Listen to my music
    May 2006
    Belgium
    Quote Originally Posted by coucouillu
    My main goal was to make it work with TomTom, didn't look into using it with Destinator. I'll see what data format destinator uses.
    Yes, but some programs need to restart before they reload the POI data.
    In most cases the name of the file would be the category name of your poi. The extension you should find yourself, also in most cases you can see it by looking to other POI files and use the same extension.
    May 2006
    Belgium
    UPDATE:
    - Added 6 more conversion formats (newer version of GPSBabel):
    * DeLorme XMap/SAHH 2006 Native .TXT
    * Franson GPSGate Simulation
    * Garmin MapSource - txt (tab delimited)
    * Kartex 5 Track File
    * Kartex 5 Waypoint File
    * Navigon Mobile Navigator .rte files
    - changed the formats list in the setup page, added the extension at the end of the description (if the extension is known)
    DOWNLOAD:
    If your upgrading from a previous version just overwrite the gpsbabel directory and the APOI.dll.
    May 2006
    Seattleish, WA
    This is great - THANK YOU! NS has been a bit "interesting" to control as an external app in CF.
    I've kinda' shifted over to WiFiHopper as my main sniffing app, but I like running NS to get the file exports.
    :: Mark
    Aug 2005
    Plano/College Station, TX
    Will this program export files in a format that iGuidance 2.1.3 can understand? I don't know much about netstumbler but I did not see iNav or iGuidance on the 'formats' list. This would be a great program otherwise!
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    IIRC David was going to make 1.7 be able to use TomTom POI's
    Don't know if he did though...
  1. Garo's Extra POI Plugin 1.0 beta 1
    By garo in forum Map Monkey
    Last Post: 01-18-2007, 01:32 PM
  2. How do I use the Base plugin sources ?
    By guino in forum RR FAQ
    Last Post: 04-24-2006, 04:43 PM
  3. Netstumbler plugin
    By CavityCr33p in forum Centrafuse
    Last Post: 08-11-2005, 08:42 AM
  4. Winamp LCD display plugin / IRMan plugin - together?
    By Jarrod in forum Software & Software Development
    Last Post: 06-03-2002, 06:39 AM
