Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 45
Thread: Hauppauge WinTV+FM USB radio plugin
  1. #21
    VENDOR - Centrafuse veetid's Avatar
    The problem is once the TV portion of the card is accessed either with Centrafuse or it's own TV program, it's messing up the radio...
    if you setup radiator to work and make sure the config.xml file in the CF Radio Module folder for Radiator has the correct path and settings in Centrafuse...
    Then restart and run just Centrafuse and click Radio, it should work just fine...
    you should be able to do the same with TV and it work fine, but not both together...
    this is the same with the TV cards own application and Radiator...
    I plan to look into using them at the same time, but it's a lock on resource issue... it throws that the hardware is already in use and the radio or tv, whichever was run second, does not work...
    david
  2. #22
    Constant Bitrate urosbe's Avatar
    Mar 2005
    Ok, I have followed your steps and still have a problem. Centrafuse is not able to control Radiator... when I click radio icon, only Radiator application appears and you can listen to the radio. If you want to tune a station you have to tune in Radiator - in Centrafuse doesn't work. I checked radiator.xml and the path is correct (default where Radiator is installed). I also tried to change the path from default:
    C:\Program Files\Radiator
    to
    C:\Program Files\Radiator\
    but it still doesn't work.
    There is also error.log and a lot of "Cannot find path or file specified" or something like that... Centrafuse doesn't find Radiator but why? And if it doesn't find it, why it opens Radiator application?
    P.S. Is there any good antenna with amplifier for both FM/UHF-TV that you can recommend?
    System: VIA EPIA EN15000,512 MB DDRII,M2-ATX,300GB HDD,XENARC 1020TSV,VoomPC case
    USB: Powermate,WinTV+FM,WLAN 54G,Bluetooth,Haicom GPS mouse SIRFIII
    Software: Windows TinyXP Rev06+MinLogon+EWF+HORM+Centrafuse 1.2
    Honda delSol project
    CarDomain
  3. #23
    Mar 2005
    "The system cannot find the file specified
    at System.Diagnostics.Process.StartWithS.....
    at Radio.Radiator.runCommand(String args)"
    Is has to be something with connection CF-Radiator, but what?
    CarDomain
  4. #24
    Jun 2006
    Check this old post of mine..
    RadioExtreme - How i can safe radio stations?
    Quote Originally Posted by SUVputer View Post
    talking about radios,
    RC4 is not controlling Radiator at all..
    I was looking in the XML file... and this is what i've found..
    Code:
    <CONFIG>
    	<RADIATORPATH>C:\Program Files\RadioXtreme\RX Radiator</RADIATORPATH>
    </CONFIG>
    RadioXtreme
    \RX Radiator
    isn't it strange?
    maybe it has something to do with your problem?
    VIA EN15000 C7 // CTF700 7" Screen // Morex 3688 Black Case
    M2-ATX // 80GB HD
    DVD-RW // PowerMate
    Belkin Bluetooth V1.2 // Hauppauge WinTV FM
    Centrafuse RC5
    JBL GTO 75.4 520W // Pionneer Kevlar 260w Speakers
  5. #25
    Mar 2005
    I check XML file few times and its cleary written:
    And I am not sure even if the path was wrong, why then Radiator application appears when I click Radio.
    I am using the latest Centrafuse 1.11. I know about problem with wrong default path in XML to Radiator application - but David fixed it in newer releases.
    CarDomain
  6. #26
    Mar 2005
    Yeah.. this is what I did, Radiator now starts with Centrafuse but I cannot change the channels from centrafuse, it has no effect.
    You had the same problem? And what was the solution?
    CarDomain
  7. #27
    Jun 2006
    If i remember well,
    fresh new install of centrafuse
    setting up radiator to work with wintv
    restart
    setting up CF radio to use radiator with Mic (not touching to TV settings)
    that's it i beleive...
    M2-ATX // 80GB HD
    DVD-RW // PowerMate
    Centrafuse RC5
  8. #28
    Mar 2005
    Yes, I have followed those steps, still the same... error "cannot find file" in error.log
    CarDomain
  9. #29
    There is suppose to be a sub folder with a file in it called...
    \Add-ons\Command line\rc.exe
    If that is not there in the Radiator directory it will not work... You should be able to find and add this easily...
    david
  10. #30
    Mar 2005
    No, there is a only
    \Add-ons\X10RC\Radiator.icf
    no Command line and rc.exe??
    You are talking about Radiator path (C:\Program Files\Radiator\Add-ons...), aren't you?
    CarDomain
  1. wintv radio not launching when i press radio
    By dnkyntz in forum RR Bug Tracker
    Last Post: 12-23-2005, 02:49 AM
  2. WTB: FM Radio for Roadrunner (Dlink USB?)
    By fromplanetbob in forum Classified Archive
    Last Post: 10-18-2005, 07:37 PM
  3. New USB FM Radio
    By sxt173 in forum General Hardware Discussion
    Last Post: 08-24-2005, 03:36 AM
  4. Hauppauge WinTV Radio PCI model 401?
    By miztahsparklez in forum Input Devices
    Last Post: 02-08-2005, 12:10 AM
  5. WTB: D-Link USB FM radio
    By Stine161 in forum Classified Archive
    Last Post: 11-12-2002, 08:02 AM
